[QGIS-ZA-user] ENV for powershell instead of osgeo4w shell
Gerhard Brits BritsJG at eskom.co.za
Sun Feb 4 22:49:53 PST 2018
Hi
So if you want to use GDAL via powershell or cmd you need have three environmental variables set.
GDAL_DATA = set to the gdal-data folder of your gdal install. In my cases "C:\Program Files\GDAL\gdal-data"
GDAL_DRIVER_PATH =  set to the gdalplugins folder of your gdal install. In my case "C:\Program Files\GDAL\gdalplugins"
You need to add gdal to the GDAL path variable. Add it to the end of the list by adding a ; . My path is "C:\Program Files\GDAL"
I hope the above helps.
Regards
-----Original Message-----
From: qgis-za-user [mailto:qgis-za-user-bounces at lists.osgeo.org] On Behalf Of Zoltan via qgis-za-user
Sent: 03 February 2018 06:09 PM
To: South Africa QGIS user group
Cc: Zoltan
Subject: [QGIS-ZA-user] ENV for powershell instead of osgeo4w shell
A quick google didn't help.
Is there anywhere I can find a definitive list of environment variables to set, so that I get full functionality using powershell instead of osgeo4w shell?
Thanks in advance,
Zoltan
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
qgis-za-user mailing list
qgis-za-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/qgis-za-user
NB: This Email and its contents are subject to the Eskom Holdings SOC Ltd EMAIL LEGAL NOTICE which can be viewed at http://www.eskom.co.za/Pages/Email_Legal_Spam_Disclaimer.aspx
More information about the qgis-za-user mailing list
