[QGIS-ZA-user] ENV for powershell instead of osgeo4w shell
Zoltan
zoltans at geograph.co.za
Mon Feb 5 08:50:37 PST 2018
Thanks Gerhard. :-)
On 2018-02-05 09:49, Gerhard Brits via qgis-za-user wrote:
> Hi
> So if you want to use GDAL via powershell or cmd you need have three environmental variables set.
> GDAL_DATA = set to the gdal-data folder of your gdal install. In my cases "C:\Program Files\GDAL\gdal-data"
> GDAL_DRIVER_PATH = set to the gdalplugins folder of your gdal install. In my case "C:\Program Files\GDAL\gdalplugins"
> You need to add gdal to the GDAL path variable. Add it to the end of the list by adding a ; . My path is "C:\Program Files\GDAL"
> I hope the above helps.
> Regards
> -----Original Message-----
> From: qgis-za-user [mailto:qgis-za-user-bounces at lists.osgeo.org] On Behalf Of Zoltan via qgis-za-user
> Sent: 03 February 2018 06:09 PM
> To: South Africa QGIS user group
> Cc: Zoltan
> Subject: [QGIS-ZA-user] ENV for powershell instead of osgeo4w shell
> Hi,
> A quick google didn't help.
> Is there anywhere I can find a definitive list of environment variables to set, so that I get full functionality using powershell instead of osgeo4w shell?
> Thanks in advance,
> Zoltan
> Zoltan Szecsei GPrGISc 0031
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323 www.geograph.co.za
> qgis-za-user mailing list
> qgis-za-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
> NB: This Email and its contents are subject to the Eskom Holdings SOC Ltd EMAIL LEGAL NOTICE which can be viewed at http://www.eskom.co.za/Pages/Email_Legal_Spam_Disclaimer.aspx
Geograph (Pty) Ltd.
More information about the qgis-za-user
