[QGIS-ZA-user] South African CRSs in QGIS
Paul Young paulysa at gmail.com
Thu Nov 15 00:08:24 PST 2018
I still have Proj4 ver 4.9.3. but run QGIS 3.4 but I think the repo is QGIS
not Ubuntu GIS. I suppose I could add the Ubuntu GIS repo into
/etc/apt/sources.list and run apt-get update and upgrade to get it to 5.2?
On Thu, 15 Nov 2018 09:17 Tim Sutton via qgis-za-user <
qgis-za-user at lists.osgeo.org wrote:
> Hi
> For those interested, you can see a detailed report on the EPSG codes
> published here (go back to the home page to tweak the search string if
> needed):
> http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::4940&entity=urn:ogc:def:crs:EPSG::4941&entity=urn:ogc:def:crs:EPSG::4148&entity=urn:ogc:def:crs:EPSG::2046&entity=urn:ogc:def:crs:EPSG::2047&entity=urn:ogc:def:crs:EPSG::2048&entity=urn:ogc:def:crs:EPSG::2049&entity=urn:ogc:def:crs:EPSG::2050&entity=urn:ogc:def:crs:EPSG::2051&entity=urn:ogc:def:crs:EPSG::2052&reportDetail=long&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=South%20African%20Projections&r=59
> QGIS uses a little internal application called crssync to populate it’s
> internal CRS database from Proj. Layered on top of that are other CRSes
> that haven’t made their way into EPSG yet. It takes a while for CRS’s to
> make their way into EPSG -> Proj -> QGIS. The ZANGI definitions were QGIS
> specific definitions that Gavin and I cooked up in the absence of these
> CRS’s being in EPSG and Proj. Please let us know if the ones provided in
> Proj 5 now deprecate the ZANGI and I will remove them from QGIS’s CRS
> database. We hope to eventually remove the need for QGIS’ own layer on top
> of the Proj database. Even (proj maintainer) has been talking about moving
> proj’s CRS database to a sqlite database so in theory we could just have
> one database that is shared between, proj, gdal, QGIS etc. which would make
> things more consistent.
> BTW Mac users are also still getting Proj 493 in the official Mac packages.
> Happy QGISsing :-)
> Regards
> Tim
> On 15 Nov 2018, at 08:52, Immo Blecher via qgis-za-user <
> qgis-za-user at lists.osgeo.org> wrote:
> Morning Frank,
> This is exactly the one I am using but it has proj 493. I will do a
> complete removal and install again, maybe some older files remain due to
> dependencies?
> Thanks for all your help.
> Regards
> Immo
> On 2018/11/14 08:37, Frank Sokolic via qgis-za-user wrote:
> Hi Immo,
> This is the repository I'm using:
> deb https://qgis.org/ubuntu cosmic main
> When I install QGIS 3.4 from this repository it loads Proj 5.1.0 which
> contains the CRSs I listed in my earlier post.
> Frank.
> On 2018/11/14 07:58, Immo Blecher via qgis-za-user wrote:
> Good Morning,
> I think the "latest" proj4 probably sits with the ubuntugis-unstable
> version. And I am on Ubuntu 18.04 LTS, which apparently does not support
> the latest ubuntugis-unstable. Or did anybody get it installed and working?
> Regards
> Immo
> On 2018/11/13 19:16, Paul Young via qgis-za-user wrote:
> Hi there I tried to pul the Docker Proj4 and it would not upgrade.
> It gave: Rel. 4.9.3, 15 August 2016
> Maybe it needs to be compiled from source?
> On Tue, 13 Nov 2018 at 12:24, Immo Blecher via qgis-za-user <
>> Hi Frank,
>> That is weird! I am on 3.4, but installed from the Debian link, not the
>> ubuntugis as there I had dependency issues. Maybe there is still a big
>> difference between the two. But I will try the ubuntugis route again. The
>> proj version obviously makes all the difference.
>> Regards
>> Immo
>> On 2018/11/13 12:20, Frank Sokolic via qgis-za-user wrote:
>> Hi Immo,
>> Not sure why they don't show up for you. I can see them on QGIS 3.14 and
>> the Proj version is 5.1.0. This is on Ubuntu Linux.
>> Regards, Frank.
>> On 2018/11/13 11:31, Immo Blecher via qgis-za-user wrote:
>> Hi QGIS Users,
>> I can't find these in my QGIS 3.4. And I see that Proj4 is still on
>> version 4.93, but the latest seems to be 5.2.
>> But what I also noticed is that Proj4 changed the way it converts from/to
>> Hartebeesthoek94 (15 to 31) from version 4.7 to vers. 4.9: Using proj4 4.7
>> to convert one had to turn around E-W and N-S, w.o.w. X = -X and Y = -Y and
>> then convert. From vers. 4.9 this was not necessary any longer so I think
>> the calculations in QGIS should be sorted out (it is actually a bug and
>> that is why everything is upside down and right=left). That would also mean
>> that we would not need the ZANGI:ZANGI projections any longer but just use
>> the built-in Hartebeesthoek94 ones.
>> For what it's worth!
>> Immo
>> On 2018/11/13 10:58, Frank Sokolic via qgis-za-user wrote:
>> Hi QGIS users,
>> I noticed last week that these CRSs have appeared in QGIS under Project
>> Coordinate Systems > Transverse Mercator:
>> EPSG:102480 Hartebeesthoek94_Lo15
>> EPSG:102481 Hartebeesthoek94_Lo17
>> EPSG:102482 Hartebeesthoek94_Lo19
>> EPSG:102483 Hartebeesthoek94_Lo21
>> EPSG:102484 Hartebeesthoek94_Lo23
>> EPSG:102485 Hartebeesthoek94_Lo25
>> EPSG:102486 Hartebeesthoek94_Lo27
>> EPSG:102487 Hartebeesthoek94_Lo29
>> EPSG:102488 Hartebeesthoek94_Lo31
>> EPSG:102489 Hartebeesthoek94_Lo33
>> EPSG:102562 Hartebeesthoek94_Lo19_(E-N)
>> EPSG:102563 Hartebeesthoek94_Lo21_(E-N)
>> EPSG:102564 Hartebeesthoek94_Lo23_(E-N)
>> EPSG:102565 Hartebeesthoek94_Lo25_(E-N)
>> EPSG:102566 Hartebeesthoek94_Lo27_(E-N)
>> EPSG:102567 Hartebeesthoek94_Lo29_(E-N)
>> EPSG:102568 Hartebeesthoek94_Lo31_(E-N)
>> Anyone know anything about them? Are these now the official South African
>> CRSs in the EPSG database? If so, where are L015_(E-N), L017_(E-N) and
>> L033_(E-N)?
>> With these new additions, there are now a few versions of the South
>> African CRSs in the QGIS CRS database (e.g. EPSG 2046 to EPSG 2055 as well
>> as ZANGI:HBKNO15 to ZANGI:HBK033) so I guess things need to be cleaned up.
>> Regards, Frank.
>> qgis-za-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
>> *Immo F. Blecher*
>> * Street: *
>> * 36 Saffraan Ave., Die Boord, Stellenbosch, 7613, South Africa *
>> *Postal:*
>> * PO Box 74, Lynedoch, 7603, South Africa **Cell:* +27 83 272 6791 | *Fax:
>> *+27 86 736 3302 *Email:* *immo at blecher.co.za* <immo at blecher.co.za> |
>> *immob19 at gmail.com* <immob19 at gmail.com> |
>> *immob at mymtnmail.co.za <immob at mymtnmail.co.za> **Internet:*
>> *http://www.blecher.co.za/* <http://www.blecher.co.za/>
>> Contact me: immob19 at gmail.com immoblecher
>> <http://www.linkedin.com/pub/immo-blecher/30/414/b8>
>> Please consider your environmental responsibility. Before printing this
>> e-mail message, ask yourself whether you really need a hard copy.
>> IMPORTANT: The contents of this email and any attachments are
>> confidential. They are intended for the named recipient(s) only. If you
>> have received this email by mistake, please notify the sender immediately
>> and do not disclose the contents to anyone or make copies thereof.
>> qgis-za-user mailing listqgis-za-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/qgis-za-user
>> *Immo F. Blecher*
>> * Street: *
>> *Postal:*
> Regards
> Paul Young
> Home: +27 (0) 31 5662608
> Work: +27 (0) 87 9432416
> Mobile: +27 (0) 84 2471544 / +27 (0) 604141439
> Google+ <http://google.com/+PaulYoung1969> ; LinkedIn
> <https://www.linkedin.com/in/paulysa1969> ; FaceBook
> <https://www.facebook.com/paulysa1969> ; Twitter
> <https://www.twitter.com/paulysa1969> ; Instagram
> <https://www.instagram.com/paulysa1969> ; Pinterest
> <https://za.pinterest.com/paulysa1969> ; SnapChat
> <https://www.snapchat.com/add/paulysa1969>
> N �n�r����)em�h�yhiם�w^���
> *Immo F. Blecher*
> * Street: *
> * 36 Saffraan Ave., Die Boord, Stellenbosch, 7613, South Africa **Postal:*
> *Immo F. Blecher*
> * Street: *
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Ex Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181115/5a8bfdc0/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181115/5a8bfdc0/attachment-0001.jpg>
More information about the qgis-za-user mailing list
