[QGIS-ZA-user] South African CRSs in QGIS
Immo Blecher immob19 at gmail.com
Wed Nov 14 23:42:47 PST 2018
Thanks Tim,
I completely removed QGIS and reinstalled with https://qgis.org.ubuntu
and still getting proj 493.
But I must also say that I have installed the proj that comes with
Ubuntu (493), as I need that for compiling another app) and I think QGIS
uses that one instead of the one coming with QGIS?
Immo
On 2018/11/15 09:17, Tim Sutton via qgis-za-user wrote:
> Hi
> For those interested, you can see a detailed report on the EPSG codes
> published here (go back to the home page to tweak the search string if
> needed):
> http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::4940&entity=urn:ogc:def:crs:EPSG::4941&entity=urn:ogc:def:crs:EPSG::4148&entity=urn:ogc:def:crs:EPSG::2046&entity=urn:ogc:def:crs:EPSG::2047&entity=urn:ogc:def:crs:EPSG::2048&entity=urn:ogc:def:crs:EPSG::2049&entity=urn:ogc:def:crs:EPSG::2050&entity=urn:ogc:def:crs:EPSG::2051&entity=urn:ogc:def:crs:EPSG::2052&reportDetail=long&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=South%20African%20Projections&r=59
> QGIS uses a little internal application called crssync to populate
> it’s internal CRS database from Proj. Layered on top of that are other
> CRSes that haven’t made their way into EPSG yet. It takes a while for
> CRS’s to make their way into EPSG -> Proj -> QGIS. The ZANGI
> definitions were QGIS specific definitions that Gavin and I cooked up
> in the absence of these CRS’s being in EPSG and Proj. Please let us
> know if the ones provided in Proj 5 now deprecate the ZANGI and I will
> remove them from QGIS’s CRS database. We hope to eventually remove the
> need for QGIS’ own layer on top of the Proj database. Even (proj
> maintainer) has been talking about moving proj’s CRS database to a
> sqlite database so in theory we could just have one database that is
> shared between, proj, gdal, QGIS etc. which would make things more
> consistent.
> BTW Mac users are also still getting Proj 493 in the official Mac
> packages.
> Happy QGISsing :-)
> Regards
> Tim
>> On 15 Nov 2018, at 08:52, Immo Blecher via qgis-za-user
>> <qgis-za-user at lists.osgeo.org <mailto:qgis-za-user at lists.osgeo.org>>
>> wrote:
>> Morning Frank,
>> This is exactly the one I am using but it has proj 493. I will do a
>> complete removal and install again, maybe some older files remain due
>> to dependencies?
>> Thanks for all your help.
>> Regards
>> Immo
>> On 2018/11/14 08:37, Frank Sokolic via qgis-za-user wrote:
>>> Hi Immo,
>>> This is the repository I'm using:
>>> deb https://qgis.org/ubuntu cosmic main
>>> When I install QGIS 3.4 from this repository it loads Proj 5.1.0
>>> which contains the CRSs I listed in my earlier post.
>>> Frank.
>>> On 2018/11/14 07:58, Immo Blecher via qgis-za-user wrote:
>>>> Good Morning,
>>>> I think the "latest" proj4 probably sits with the
>>>> ubuntugis-unstable version. And I am on Ubuntu 18.04 LTS, which
>>>> apparently does not support the latest ubuntugis-unstable. Or did
>>>> anybody get it installed and working?
>>>> Regards
>>>> Immo
>>>> On 2018/11/13 19:16, Paul Young via qgis-za-user wrote:
>>>>> Hi there I tried to pul the Docker Proj4 and it would not upgrade.
>>>>> It gave: Rel. 4.9.3, 15 August 2016
>>>>> Maybe it needs to be compiled from source?
>>>>> On Tue, 13 Nov 2018 at 12:24, Immo Blecher via qgis-za-user
>>>>> <mailto:qgis-za-user at lists.osgeo.org>> wrote:
>>>>>     Hi Frank,
>>>>>     That is weird! I am on 3.4, but installed from the Debian
>>>>>     link, not the ubuntugis as there I had dependency issues.
>>>>>     Maybe there is still a big difference between the two. But I
>>>>>     will try the ubuntugis route again. The proj version obviously
>>>>>     makes all the difference.
>>>>>     Regards
>>>>>     Immo
>>>>>     On 2018/11/13 12:20, Frank Sokolic via qgis-za-user wrote:
>>>>>>     Hi Immo,
>>>>>>     Not sure why they don't show up for you. I can see them on
>>>>>>     QGIS 3.14 and the Proj version is 5.1.0. This is on Ubuntu Linux.
>>>>>>     Regards, Frank.
>>>>>>     On 2018/11/13 11:31, Immo Blecher via qgis-za-user wrote:
>>>>>>>     Hi QGIS Users,
>>>>>>>     I can't find these in my QGIS 3.4. And I see that Proj4 is
>>>>>>>     still on version 4.93, but the latest seems to be 5.2.
>>>>>>>     But what I also noticed is that Proj4 changed the way it
>>>>>>>     converts from/to Hartebeesthoek94 (15 to 31) from version
>>>>>>>     4.7 to vers. 4.9: Using proj4 4.7 to convert one had to turn
>>>>>>>     around E-W and N-S, w.o.w. X = -X and Y = -Y and then
>>>>>>>     convert. From vers. 4.9 this was not necessary any longer so
>>>>>>>     I think the calculations in QGIS should be sorted out (it is
>>>>>>>     actually a bug and that is why everything is upside down and
>>>>>>>     right=left). That would also mean that we would not need the
>>>>>>>     ZANGI:ZANGI projections any longer but just use the built-in
>>>>>>>     Hartebeesthoek94 ones.
>>>>>>>     For what it's worth!
>>>>>>>     Immo
>>>>>>>     On 2018/11/13 10:58, Frank Sokolic via qgis-za-user wrote:
>>>>>>>>     Hi QGIS users,
>>>>>>>>     I noticed last week that these CRSs have appeared in QGIS
>>>>>>>>     under Project Coordinate Systems > Transverse Mercator:
>>>>>>>>     EPSG:102480 Hartebeesthoek94_Lo15
>>>>>>>>     EPSG:102481 Hartebeesthoek94_Lo17
>>>>>>>>     EPSG:102482 Hartebeesthoek94_Lo19
>>>>>>>>     EPSG:102483 Hartebeesthoek94_Lo21
>>>>>>>>     EPSG:102484 Hartebeesthoek94_Lo23
>>>>>>>>     EPSG:102485 Hartebeesthoek94_Lo25
>>>>>>>>     EPSG:102486 Hartebeesthoek94_Lo27
>>>>>>>>     EPSG:102487 Hartebeesthoek94_Lo29
>>>>>>>>     EPSG:102488 Hartebeesthoek94_Lo31
>>>>>>>>     EPSG:102489 Hartebeesthoek94_Lo33
>>>>>>>>     EPSG:102562 Hartebeesthoek94_Lo19_(E-N)
>>>>>>>>     EPSG:102563 Hartebeesthoek94_Lo21_(E-N)
>>>>>>>>     EPSG:102564 Hartebeesthoek94_Lo23_(E-N)
>>>>>>>>     EPSG:102565 Hartebeesthoek94_Lo25_(E-N)
>>>>>>>>     EPSG:102566 Hartebeesthoek94_Lo27_(E-N)
>>>>>>>>     EPSG:102567 Hartebeesthoek94_Lo29_(E-N)
>>>>>>>>     EPSG:102568 Hartebeesthoek94_Lo31_(E-N)
>>>>>>>>     Anyone know anything about them? Are these now the official
>>>>>>>>     South African CRSs in the EPSG database? If so, where are
>>>>>>>>     L015_(E-N), L017_(E-N) and L033_(E-N)?
>>>>>>>>     With these new additions, there are now a few versions of
>>>>>>>>     the South African CRSs in the QGIS CRS database (e.g. EPSG
>>>>>>>>     2046 to EPSG 2055 as well as ZANGI:HBKNO15 to ZANGI:HBK033)
>>>>>>>>     so I guess things need to be cleaned up.
>>>>>>>>     Regards, Frank.
>>>>>>>>     _______________________________________________
>>>>>>>>     qgis-za-user mailing list
>>>>>>>>     https://lists.osgeo.org/mailman/listinfo/qgis-za-user
>>>>>>>     *Immo F. Blecher**
>>>>>>>     Street: */36 Saffraan Ave., Die Boord, Stellenbosch, 7613,
>>>>>>>     South Africa
>>>>>>>     //*Postal:*//PO Box 74, Lynedoch, 7603, South Africa
>>>>>>>     //*Cell:*///+27 83 272 6791 |*Fax: *+27 86 736 3302
>>>>>>>     *Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
>>>>>>>     _immob19 at gmail.com_ <mailto:immob19 at gmail.com>|
>>>>>>>     _immob at mymtnmail.co.za <mailto:immob at mymtnmail.co.za>
>>>>>>>     _*Internet:*_http://www.blecher.co.za/_
>>>>>>>     Contact me: immob19 at gmail.com <mailto:immob19 at gmail.com>
>>>>>>>     immoblecher
>>>>>>>     <http://www.linkedin.com/pub/immo-blecher/30/414/b8>
>>>>>>>     Please consider your environmental responsibility. Before
>>>>>>>     printing this e-mail message, ask yourself whether you
>>>>>>>     really need a hard copy.
>>>>>>>     IMPORTANT: The contents of this email and any attachments
>>>>>>>     are confidential. They are intended for the named
>>>>>>>     recipient(s) only. If you have received this email by
>>>>>>>     mistake, please notify the sender immediately and do not
>>>>>>>     disclose the contents to anyone or make copies thereof.
>>>>>     *Immo F. Blecher**
>>>>>     South Africa
>>>>>     immoblecher
>>>>>     printing this e-mail message, ask yourself whether you really
>>>>>     need a hard copy.
>>>>>     IMPORTANT: The contents of this email and any attachments are
>>>>>     confidential. They are intended for the named recipient(s)
>>>>>     only. If you have received this email by mistake, please
>>>>>     notify the sender immediately and do not disclose the contents
>>>>> Regards
>>>>> Paul Young
>>>>> Home: +27 (0) 31 5662608
>>>>> Work: +27 (0) 87 9432416
>>>>> Mobile: +27 (0) 84 2471544 / +27 (0) 604141439
>>>>> Google+ <http://google.com/+PaulYoung1969> ; LinkedIn
>>>>> <https://www.linkedin.com/in/paulysa1969> ; FaceBook
>>>>> <https://www.facebook.com/paulysa1969> ; Twitter
>>>>> <https://www.twitter.com/paulysa1969> ; Instagram
>>>>> <https://www.instagram.com/paulysa1969> ; Pinterest
>>>>> <https://za.pinterest.com/paulysa1969> ; SnapChat
>>>>> <https://www.snapchat.com/add/paulysa1969>
>>>>> N�n�r����)em�h�yhiם�w^���
>>>> *Immo F. Blecher**
>>>> Street: */36 Saffraan Ave., Die Boord, Stellenbosch, 7613, South Africa
>>>> Contact me: immob19 at gmail.com immoblecher
>>>> Please consider your environmental responsibility. Before printing
>>>> this e-mail message, ask yourself whether you really need a hard copy.
>>>> confidential. They are intended for the named recipient(s) only. If
>>>> you have received this email by mistake, please notify the sender
>>>> immediately and do not disclose the contents to anyone or make
>>>> copies thereof.
>> *Immo F. Blecher**
>> immediately and do not disclose the contents to anyone or make copies
>> thereof.
> *Tim Sutton*
> *Co-founder:*Kartoza
> *Ex Project chair:*QGIS.org <http://QGIS.org>
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:*timlinux on #qgis at freenode.net <http://freenode.net>
*Immo F. Blecher**
_immob19 at gmail.com_ <mailto:immob19 at gmail.com>| _immob at mymtnmail.co.za
Please consider your environmental responsibility. Before printing this
confidential. They are intended for the named recipient(s) only. If you
thereof.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181115/721d8a4b/attachment-0001.html>
More information about the qgis-za-user mailing list
