[QGIS-ZA-user] Coordinates along the map border
Frank Sokolic sokolic at worldonline.co.za
Tue Oct 23 08:23:09 PDT 2018
Hi Maligana,
Please check that the CRS settings for your layers are also correct. For
example, if you've set the layer CRSs to WGS 4326 when they are actually
something else, e.g. UTM 35S or WG27, then you'll get the problems you
are seeing.
Frank.
On 2018/10/23 11:59, Maligana Rendani via qgis-za-user wrote:
> Hi, I am using the WGS84 4326, i have attached a sample of a map
> produced, with wrong coordinates along the border
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
> *From: *Frank Sokolic via qgis-za-user
> <mailto:qgis-za-user at lists.osgeo.org>
> *Sent: *Monday, 22 October 2018 4:42 PM
> *To: *qgis-za-user at lists.osgeo.org <mailto:qgis-za-user at lists.osgeo.org>
> *Cc: *Frank Sokolic <mailto:sokolic at worldonline.co.za>
> *Subject: *Re: [QGIS-ZA-user] Coordinates along the map border
> Hi Maligana,
> You need to make sure that project CRS is set correctly as well as the
> CRS of the map in your layout. Once those are correct you can then
> configure the settings for the map grid. What are the CRS settings you
> are currently using?
> Frank.
> On 2018/10/22 16:22, Maligana Rendani via qgis-za-user wrote:
>     Hi
>     Can you please assist im using Las Palmas version of QGIS, and
>     i've been having some difficulties trying to show the coordinates
>     along the map borders, when trying to do so, it always shows wrong
>     coordinates, can you please assist
>     Regards
>     _______________________________________________
>     qgis-za-user mailing list
>     https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181023/5190d0ef/attachment.html>
More information about the qgis-za-user mailing list
