[QGIS-ZA-user] Coordinates along the map border
Immo Blecher
immo at blecher.co.za
Tue Oct 23 23:23:37 PDT 2018
Hi Maligana,
When I look at your map I guess you took a scanned image of the
geological map? Has this image been geo-referenced under the correct
CRS indicated on the map? I think is where you should start! Once that
is done you will see that if you only open the image the coordinate
system will come right. Then you can add your other layers.
RegardsImmo
On Tue, 2018-10-23 at 17:23 +0200, Frank Sokolic via qgis-za-user
wrote:
> Hi Maligana,
> Please check that the CRS settings for
> your layers are also correct. For example, if you've set the
> layer
> CRSs to WGS 4326 when they are actually something else, e.g.
> UTM
> 35S or WG27, then you'll get the problems you are seeing.
> Frank.
> On 2018/10/23 11:59, Maligana Rendani
> via qgis-za-user wrote:
> > /* Font Definitions */
> > @font-face
> > {font-family:"Cambria Math";
> > panose-1:2 4 5 3 5 4 6 3 2 4;}
> > @font-face
> > {font-family:Calibri;
> > panose-1:2 15 5 2 2 2 4 3 2 4;}
> > /* Style Definitions */
> > p.MsoNormal, li.MsoNormal, div.MsoNormal
> > {margin:0cm;
> > margin-bottom:.0001pt;
> > font-size:11.0pt;
> > font-family:"Calibri",sans-serif;}
> > a:link, span.MsoHyperlink
> > {mso-style-priority:99;
> > color:blue;
> > text-decoration:underline;}
> > a:visited, span.MsoHyperlinkFollowed
> > color:#954F72;
> > pre
> > mso-style-link:"HTML Preformatted Char";
> > margin:0cm;
> > font-size:10.0pt;
> > font-family:"Courier New";
> > color:black;}
> > span.HTMLPreformattedChar
> > {mso-style-name:"HTML Preformatted Char";
> > mso-style-link:"HTML Preformatted";
> > color:black;}
> > .MsoChpDefault
> > {mso-style-type:export-only;}
> > @page WordSection1
> > {size:612.0pt 792.0pt;
> > margin:72.0pt 72.0pt 72.0pt 72.0pt;}
> > div.WordSection1
> > {page:WordSection1;}
> > Hi, I am using the WGS84 4326, i have
> > attached a sample of a map produced, with wrong
> > coordinates
> > along the border
> > Sent from Mail for Windows 10
> > From:
> > Sent: Monday, 22 October 2018 4:42 PM
> > To: qgis-za-user at lists.osgeo.org
> > Cc: Frank Sokolic
> > Subject: Re: [QGIS-ZA-user] Coordinates along the
> > map border
> > Hi Maligana,
> > You need to make sure that project CRS is
> > set correctly as well as the CRS of the map in your
> > layout.
> > Once those are correct you can then configure the
> > settings
> > for the map grid. What are the CRS settings you are
> > currently using?
> > Frank.
> > On 2018/10/22 16:22, Maligana Rendani via
> > qgis-za-user wrote:
> > > Hi
> > > Can you please assist im using Las
> > > Palmas version of QGIS, and i've been having
> > > some
> > > difficulties trying to show the coordinates along
> > > the
> > > map borders, when trying to do so, it always
> > > shows wrong
> > > coordinates, can you please assist
> > > Regards
> > > _______________________________________________
> > > qgis-za-user mailing list
> > > https://lists.osgeo.org/mailman/listinfo/qgis-za-user
> > _______________________________________________qgis-za-user
> > mailing listqgis-za-user at lists.osgeo.org
> _______________________________________________qgis-za-user mailing
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181024/198110e6/attachment.html>
More information about the qgis-za-user
