[QGIS-ZA-user] Curved Road Labeling Issue
    Gavin Fleming
    gavin at kartoza.com
    Mon Apr 15 23:56:06 PDT 2019
Catherine sent me some sample data and this was my response to her - it was just a matter of working in a projected CRS (as one should always do for cartography)
’it just works’
QGIS 3.6
all I did was to select ‘curved’
note when you make maps you must use a projected CRS - in this case LO31 (‘HBKNO31’ in QGIS). Just maybe you were in 4326 and using units that don’t make sense with unprojected geometry?
> On 03 Apr 2019, at 12:22, Gavin Fleming <gavin at kartoza.com> wrote:
> Hi Catherine
> Are you sure you haven’t made labels scale dependent and they’re disabled at that scale?
> You should be able to do it fine with the ’single label’ option. Those options don’t affect placement.
> If you’re prepared to share some or all of your data with me or the list that would help.
> Gavin
>> On 03 Apr 2019, at 12:03, Cath Souchon via qgis-za-user <qgis-za-user at lists.osgeo.org> wrote:
>> Hello,
>> I am hoping someone can assist me. I work on a game reserve and am currently making a new map of all roads. I have captured (ground-truthed) all roads and now am working on the aesthetics part (symbolization & labeling). I am currently working on QGIS Version: 3.6.0 (Noosa).
>> I feel like I have tried everything to get the labels to follow the curves of the roads at 1:20 000 but I am just not winning. I have watched & read what feels like many hours of videos and tutorials online but still no success.
>> In the "Labels" section of the Road layer properties window I have tried selecting the "Curved" option under "Placement" but once selected all road names seem to disappear. I then tried different variations of the "Allowed positions" options but still no luck. I also tried adjusting the "Maximum angle between curved characters" but that didn't seem to make a difference, at higher numbers one or two letters of words appeared.
>> For the above explanation I had been using "Single labels". Should I rather be trying this using "Rule-based labeling"?
>> Below is a screenshot of a portion of the road network I am dealing with. The end goal is to get the map printed out (at about 1:20 000) on A0 or larger size.
>> <image.png>
>> Any help on this would be hugely appreciated!
>> Kind regards,
>> Catherine
>> qgis-za-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20190416/9330d0b8/attachment-0001.html>
Name: Screenshot 2019-04-03 at 16.28.55.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20190416/9330d0b8/attachment-0001.png>
More information about the qgis-za-user
