[QGIS-ZA-user] Coordinate conversion from Cape Datum Lo27? to EGS 84
Ryk Taljaard ryk at boundaryhunter.co.za
Tue Apr 2 01:32:58 PDT 2024
I use the attached spreadsheet for calculation of CAPE to WGS84  transformation of coordinate values, for data obtained from specific SG diagrams.
TRIG 1 is the trig beacon closest to the study area and the resulting values used for the relevant transformation calculation.
TRIG 2 is 2nd closest to the study are and used only for indication of any possible gross error.
Take note of:
(1) The pos/neg switch of coordinate values required for GIS purposes and
(2) Beware of the study area, TRIG1 and TRIG2 being located in different LO-systems.
Mowbray makes available the localities of all TRIG beacons in KML format, as well as the coordinates of all TRIG beacons in both Clarke1880 and WGS84 in TXT format, to use as input to the attached spreadsheet.
Best regards
Ryk Taljaard
Boundary Hunter
Mobile: 082 895 2906
1 Joerning Street * Paarl * 7646 * SOUTH AFRICA
Web:   <http://www.boundaryhunter.co.za/> www.boundaryhunter.co.za * Email:  <mailto:ryk at boundaryhunter.co.za> ryk at boundaryhunter.co.za
From: qgis-za-user [mailto:qgis-za-user-bounces at lists.osgeo.org] On Behalf Of Gavin Fleming via qgis-za-user
Sent: Tuesday, 02 April 2024 09:51
To: South Africa QGIS user group
Cc: Gavin Fleming
Subject: Re: [QGIS-ZA-user] Coordinate conversion from Cape Datum Lo27? to EGS 84
Hi Jordan and thanks FC
I’m not sure how FC did the projection / transformation but you can use QGIS, proj or a number of other tools.
An issue to be aware of is that no GIS will do an accurate datum transformation from Cape to WGS84/Hartebeeshoek94 since there are different errors all over the country, as much as 300m. If you need accuracy, rather speak to a land surveyor, who can do a local transformation taking into account the known errors.
Gavin
On 22 Mar 2024, at 09:25, Jordaan Fouche via qgis-za-user <qgis-za-user at lists.osgeo.org> wrote:
Thank you FC, what software did you use to do the transformation?
Could you explain in a bit more detail?
Jordaan Fouche
Portion 11
Van Reenen Country Estate
Van Reenen
3372
Republic of South Africa
Tel: +27 (0)82 555 4227
Sent: Thursday, March 21, 2024 8:26 PM
To: qgis-za-user at lists.osgeo.org
Cc: j.fouche9 at gmail.com
Just a slight edit to the Google Maps link:
https://maps.app.goo.gl/VVS9XDfhjp88dXw97
And if you prefer OSM:
https://www.openstreetmap.org/?mlat=-26.82808180999955 <https://www.openstreetmap.org/?mlat=-26.82808180999955&mlon=28.591287809999518#map=12/-26.8281/28.5913> &mlon=28.591287809999518#map=12/-26.8281/28.5913
  _____
From: qgis-za-user <qgis-za-user-bounces at lists.osgeo.org> on behalf of FC Basson via qgis-za-user <qgis-za-user at lists.osgeo.org>
Sent: 21 March 2024 20:09
To: qgis-za-user at lists.osgeo.org <qgis-za-user at lists.osgeo.org>
Cc: FC Basson <FC.Basson at westerncape.gov.za>; j.fouche9 at gmail.com <j.fouche9 at gmail.com>
I was able to locate the farm and can confirm that the coordinate should be in LO 29.
<image001.png>
For GIS purposes, we use the rotated coordinate system, so the coordinates should be X: -40600, Y: -2968350, which converts to geographic coordinate of Lat: -26.828082, Lon: 28.591288, if you assume the input datum is Cape.  And here is a link to the location in Google Maps: https://maps.app.goo.gl/bEwU4pMa35Db2gpNA
Regards
FC Basson
  _____
From: qgis-za-user <qgis-za-user-bounces at lists.osgeo.org> on behalf of Jordaan Fouche via qgis-za-user <qgis-za-user at lists.osgeo.org>
Sent: 21 March 2024 17:14
Cc: j.fouche9 at gmail.com <j.fouche9 at gmail.com>
Subject: [QGIS-ZA-user] Coordinate conversion from Cape Datum Lo27? to EGS 84
Have a set of old borehole data that I wish to plot in QGIS.
They were clearly drilled pre 1994 (Hartebeesthoek) and I am really struggling to plot them on QGIS. I suspect they may be Cape Datum.
The example that I am including is on the farm Rietvley 600 in the Balfour district.
The coordinates are legible as X:2968350;Y: 40600.
Can somebody please help me.
Jordaan Fouche
Portion 11
Van Reenen
3372
"All views or opinions expressed in this electronic message and its attachments are the view of the sender and do not necessarily reflect the views and opinions of the Western Cape Government (the WCG). No employee of the WCG is entitled to conclude a binding contract on behalf of the WCG unless he/she is an accounting officer of the WCG, or his or her authorised representative.
The information contained in this message and its attachments may be confidential or privileged and is for the use of the named recipient only, except where the sender specifically states otherwise.
If you are not the intended recipient you may not copy or deliver this message to anyone."
qgis-za-user mailing list
 <mailto:qgis-za-user at lists.osgeo.org> qgis-za-user at lists.osgeo.org
 <https://lists.osgeo.org/mailman/listinfo/qgis-za-user> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20240402/4b56dfed/attachment-0001.htm>
Type: application/vnd.ms-excel
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20240402/4b56dfed/attachment-0001.xls>
More information about the qgis-za-user mailing list
