[VisCom] OSGeo Presentation Template - Draft - Review and Comment by Tues 6/6
Michael P. Gerlek
mpg at lizardtech.com
Wed Jun 7 20:11:12 EDT 2006
Using Perry's template, I dumped some (DRAFT!) content into it -- it
looks ok, but somehow seems lacking in color. See attached.
(Note I had to punt on the PowerPoint conversion as things came out
kinda weird, and I had some Issues with Impress not laying things out
the way I like them to, but it's a start.)
I'm thinking about playing with the following sorts of tweaks:
1- a thin, clean green line below the title line?
2- introduction of a new color to the pallette, to be
used for body text (where we want to set something
off from the default black)
3- 1st-level bullets should be green; maybe slightly
different shades of green as we nest in deeper?
4- the "section" slide definitely needs another visual
element -- maybe the "thin green line" from above
could play in here too?
5- I'm not sure I like the font -- a little too sans for
my tastes?
6- could the Giant Background Wheel be positioned on the
right side, instead of the left? This might make it
clash less with the left-justified body text [unless
you're doing content with one of those right-to-left
alphabets...]
Also, there was an Autodesk copyright on the master, which I removed.
I might play with this some more over the weekend and see what I can
come up with... but in any case, it's a great start and perfectly
usable for Where as is.
-mpg
More information about the Viscom-dev
