[VisCom] OSGeo Presentation Template - Draft - Review and Comment by Tues 6/6
Michael P. Gerlek
mpg at lizardtech.com
Wed Jun 7 20:12:36 EDT 2006
(sorry, attached this time)
-mpg
> -----Original Message-----
> From: Michael P. Gerlek [mailto:mpg at lizardtech.com]
> Sent: Wednesday, June 07, 2006 5:11 PM
> To: dev at visibilitycommittee.osgeo.org
> Subject: RE: [VisCom] OSGeo Presentation Template - Draft -
> Using Perry's template, I dumped some (DRAFT!) content into it -- it
> looks ok, but somehow seems lacking in color. See attached.
> (Note I had to punt on the PowerPoint conversion as things came out
> kinda weird, and I had some Issues with Impress not laying things out
> the way I like them to, but it's a start.)
> I'm thinking about playing with the following sorts of tweaks:
> 1- a thin, clean green line below the title line?
> 2- introduction of a new color to the pallette, to be
> used for body text (where we want to set something
> off from the default black)
> 3- 1st-level bullets should be green; maybe slightly
> different shades of green as we nest in deeper?
> 4- the "section" slide definitely needs another visual
> element -- maybe the "thin green line" from above
> could play in here too?
> 5- I'm not sure I like the font -- a little too sans for
> my tastes?
> 6- could the Giant Background Wheel be positioned on the
> right side, instead of the left? This might make it
> clash less with the left-justified body text [unless
> you're doing content with one of those right-to-left
> alphabets...]
> Also, there was an Autodesk copyright on the master, which I removed.
> I might play with this some more over the weekend and see what I can
> come up with... but in any case, it's a great start and perfectly
> usable for Where as is.
> -mpg
> To unsubscribe, e-mail: dev-unsubscribe at visibilitycommittee.osgeo.org
> For additional commands, e-mail:
> dev-help at visibilitycommittee.osgeo.org
Name: OSGeo-GeoWeb - new.odp
Type: application/octet-stream
Desc: OSGeo-GeoWeb - new.odp
Url : http://lists.osgeo.org/pipermail/viscom-dev/attachments/20060607/230ec866/OSGeo-GeoWeb-new.obj
More information about the Viscom-dev
