[VisCom] Re: [OSGeo-Discuss] Terms of logo use and linking)
Jennifer Daehler Jennifer.Daehler at autodesk.com
Tue Sep 26 13:59:23 EDT 2006
Hi Tyler,
I'm attaching here some draft guidelines that I did some time ago for
OSGeo.  I've simplified them somewhat in response to some questions from
the mail lists in the past.
I think this would be a good starting point for VisCom to consider.
In particular, see my comment regarding approval for logo usage -- which
is inserted in a comment box within the document.  Something for your
consideration (and the board's probably).
Best regards,
Jennifer Daehler
Intellectual Property Counsel
Autodesk, Inc.
111 McInnis Parkway
San Rafael, California 94903
Direct	415 507-6553
Fax   	415 507-6126
-----Original Message-----
Sent: Monday, September 25, 2006 1:58 PM
To: dev at visibilitycommittee.osgeo.org
Cc: board at board.osgeo.org
Subject: [OSGeo-Board] Re: [VisCom] VisCom's abilities (was RE: [VisCom]
> If there's an implication by someone that VisCom needs to do more,
> then please do speak up and be specific.  I'll be the first to
> admit that we are / I am overcommitted-- but using volunteer-based
> resources I don't see VisCom able to be very useful anytime soon,
> outside of the areas we are already trying to cover.
I don't think there is any implying going on, just more 'hot potatoe'
with the whole logo/logo use/image topic.  The board sees that the logo
usage issues have to be ironed out sooner than later.  Since it's
already on our plate (or somewhere on our todo list) to put up some
usage guidelines, then we should still try to.  But if we can't do it
soon-ish then the board will still want to find a way to get it done.
If that makes sense...
But I think your trademark page is already a good start.
Tyler
To unsubscribe, e-mail: board-unsubscribe at board.osgeo.org
For additional commands, e-mail: board-help at board.osgeo.org
Name: Trademark Guidelines.doc
Type: application/msword
Desc: Trademark Guidelines.doc
Url : http://lists.osgeo.org/pipermail/viscom-dev/attachments/20060926/dc7ea015/TrademarkGuidelines.doc
More information about the Viscom-dev mailing list
