[Viscom-dev] Event listings updated
Michael P. Gerlek mpg at lizardtech.com
Sat Jan 27 18:34:33 EST 2007
I had trouble with the timezone stuff when I added them -- I was able to set a "user locale" sort of thing, but then everything got wierded out.
I asked Frank/Tyler if "time" could be an optional field for this very reason, but it turned out to be nontrivial.
I will try and resolve on Monday.
-mpg
-----Original Message-----
From: viscom-dev-bounces at lists.osgeo.org on behalf of Markus Neteler
Sent: Sat 1/27/2007 1:43 AM
To: Visibility Committee Discussion List
Subject: Re: [Viscom-dev] Event listings updated
On 1/26/07, Tyler Mitchell <tylermitchell at shaw.ca> wrote:
> Note it is also now available as an RSS feed:
> http://www.osgeo.org/event/feed
> Consider it beta until you've tried it for a few months.
Very nice! Please consider to
- use only 1 timezone (currently mixture)
- select UTC/GMT as this reference timezone as "vendor neutral"
Markus
> Also, if you want/need to post event items, let me or Michael know.
> We can post them or give you a login to do it (though log in
> mechanism is in flux at the moment).
> Tyler
> On 26-Jan-07, at 11:03 AM, Michael P. Gerlek wrote:
> > FYI, we have now moved all the event listings from the wiki over to
> > the
> > new Drupal site: http://www.osgeo.org/event.
> > -mpg
> > Viscom-dev mailing list
> > Viscom-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/viscom-dev
Open Source Geospatial Foundation
http://osgeo.org/grass
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/viscom-dev/attachments/20070127/184bedcb/attachment.bin
More information about the Viscom-dev mailing list
