[Viscom-dev] Event listings updated
Michael P. Gerlek mpg at lizardtech.com
Wed Jan 31 17:37:41 EST 2007
OK, I have updated all events to reflect their local timezones, and if
the event start/end time is not known I have used 00:00/23:59.
(Interestingly, when you go to create a new event the start/end times
seem to get set to random values...)
-mpg
> -----Original Message-----
> From: viscom-dev-bounces at lists.osgeo.org
> [mailto:viscom-dev-bounces at lists.osgeo.org] On Behalf Of
> Michael P. Gerlek
> Sent: Saturday, January 27, 2007 3:35 PM
> To: Visibility Committee Discussion List
> Subject: RE: [Viscom-dev] Event listings updated
> I had trouble with the timezone stuff when I added them -- I
> was able to set a "user locale" sort of thing, but then
> everything got wierded out.
> I asked Frank/Tyler if "time" could be an optional field for
> this very reason, but it turned out to be nontrivial.
> I will try and resolve on Monday.
> -mpg
> From: viscom-dev-bounces at lists.osgeo.org on behalf of Markus Neteler
> Sent: Sat 1/27/2007 1:43 AM
> Subject: Re: [Viscom-dev] Event listings updated
> On 1/26/07, Tyler Mitchell <tylermitchell at shaw.ca> wrote:
> > Note it is also now available as an RSS feed:
> > http://www.osgeo.org/event/feed
> > Consider it beta until you've tried it for a few months.
> Very nice! Please consider to
> - use only 1 timezone (currently mixture)
> - select UTC/GMT as this reference timezone as "vendor neutral"
> Markus
> > Also, if you want/need to post event items, let me or Michael know.
> > We can post them or give you a login to do it (though log in
> > mechanism is in flux at the moment).
> > Tyler
> > On 26-Jan-07, at 11:03 AM, Michael P. Gerlek wrote:
> > > FYI, we have now moved all the event listings from the
> wiki over to
> > > the
> > > new Drupal site: http://www.osgeo.org/event.
> > > -mpg
> > > _______________________________________________
> > > Viscom-dev mailing list
> > > Viscom-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/viscom-dev
> Open Source Geospatial Foundation
> http://osgeo.org/grass
More information about the Viscom-dev mailing list
