[VisCom] OSGeo Flyer for Where 2.0 - review by Friday noon PST
Tyler Mitchell
tylermitchell at shaw.ca
Fri May 19 12:49:18 EDT 2006
> Tyler, what is preferred format? SVG or Postscript?
> What design programdo you use?
I'm using Scribus. I need an EPS format file that uses options: PS3, printer neutral and with embedded fonts. Those are InDesign options that should mean something to the designers I hope :)
If I can get a copy of even the current version of the ad in that format, then I can confirm quickly whether it will work for me or not.
Tyler
More information about the Visibilitycommittee_dev
