[webmap-discuss] Re: Map Width/Height defined as a percentage in OWS Context
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Wed Dec 6 17:06:36 EST 2006
What if the context is not being used by an HTML client?
> -----Original Message-----
> From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
> Sent: 06 December, 2006 5:05 PM
> To: Kralidis,Tom [Burlington]
> Cc: ows-4-geodss at opengeospatial.org; webmap-discuss at mail.osgeo.org
> Subject: [webmap-discuss] Re: Map Width/Height defined as a
> Width would be set to 100% of the size of the <DIV> (in line
> with HTML convensions). The will often be 100% of the browser
> window width.
> >>Sent: 06 December, 2006 4:32 PM
> >>To: 'ows-4-geodss at opengeospatial.org';
> >>webmap-discuss at mail.osgeo.org; Kralidis,Tom [Burlington]
> >>Subject: Map Width/Height defined as a percentage in OWS Context
> >>Tom,
> >>Am I right in understanding that WMC and OWS Context always specify
> >>Map Size in fixed coordinates. Eg:
> >>     <Window width="600" height="300"/>
> > Correct.  This was originally from the WMC days.
> >>With modern webmapping clients these days, maps are set to
> fit within
> >>the HTML <DIV> element that encloses them.
> >>So what would work better for the context is to set window size as:
> >>     <Window width="100%" height="100%"/>
> >>The Area of Interest would then need to be calculated to fit the
> >>specified BoundingBox. (We need to make the assumption that users
> >>don't want to stretch images).
> > 100% of what?  This is assuming that a client has a width/height in
> > place when loading a context.  What if my client purely
> derived from
> > what a WMC/OWSContext provided in Window/@width and Window/@height ?
> > Similarly, we encountered this when working on WMC 1.0.0 (i.e.
> > honouring bbox vs. window size).  It was decided that it
> would be up
> > to the client on whether to recalculate the bbox or adjust
> the window
> > width/height (i.e. when aspect ratio is off).
> > I would see this same behavious (i.e. letting the client decide) as
> > can be applied to modern webmapping clients also.
> > Does this make sense?
> >>Could you please add this to your OWS Context issues to
> >>address/discuss.
> > For sure.  Thanks.
> >>Cameron Shorter
> >>http://cameron.shorter.net
> Cameron Shorter
> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
More information about the Webmap-discuss mailing list
