[webmap-discuss] Re: Map Width/Height defined as a percentage
in OWS Context
Cameron Shorter
cameron.shorter at gmail.com
Wed Dec 6 17:10:22 EST 2006
I assume that anything that is rendering a map has a window or a Pane
concept which has width/height attributes.
100% = as big as you can make the map using your current display device.
50% = half of the Window width.
etc.
Kralidis,Tom [Burlington] wrote:
> What if the context is not being used by an HTML client?
>>-----Original Message-----
>>From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>Sent: 06 December, 2006 5:05 PM
>>To: Kralidis,Tom [Burlington]
>>Cc: ows-4-geodss at opengeospatial.org; webmap-discuss at mail.osgeo.org
>>Subject: [webmap-discuss] Re: Map Width/Height defined as a
>>percentage in OWS Context
>>Width would be set to 100% of the size of the <DIV> (in line
>>with HTML convensions). The will often be 100% of the browser
>>window width.
>>>>Sent: 06 December, 2006 4:32 PM
>>>>To: 'ows-4-geodss at opengeospatial.org';
>>>>webmap-discuss at mail.osgeo.org; Kralidis,Tom [Burlington]
>>>>Subject: Map Width/Height defined as a percentage in OWS Context
>>>>Tom,
>>>>Am I right in understanding that WMC and OWS Context always specify
>>>>Map Size in fixed coordinates. Eg:
>>>> <Window width="600" height="300"/>
>>>Correct. This was originally from the WMC days.
>>>>With modern webmapping clients these days, maps are set to
>>fit within
>>>>the HTML <DIV> element that encloses them.
>>>>So what would work better for the context is to set window size as:
>>>> <Window width="100%" height="100%"/>
>>>>The Area of Interest would then need to be calculated to fit the
>>>>specified BoundingBox. (We need to make the assumption that users
>>>>don't want to stretch images).
>>>100% of what? This is assuming that a client has a width/height in
>>>place when loading a context. What if my client purely
>>derived from
>>>what a WMC/OWSContext provided in Window/@width and Window/@height ?
>>>Similarly, we encountered this when working on WMC 1.0.0 (i.e.
>>>honouring bbox vs. window size). It was decided that it
>>would be up
>>>to the client on whether to recalculate the bbox or adjust
>>the window
>>>width/height (i.e. when aspect ratio is off).
>>>I would see this same behavious (i.e. letting the client decide) as
>>>can be applied to modern webmapping clients also.
>>>Does this make sense?
>>>>Could you please add this to your OWS Context issues to
>>>>address/discuss.
>>>For sure. Thanks.
>>>>Cameron Shorter
>>>>http://cameron.shorter.net
>>Cameron Shorter
>>To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
>>For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
Cameron Shorter
More information about the Webmap-discuss
