[webmap-discuss] Re: Mapbuilder is ready for OSGeo Graduation - and project merging
Christopher Schmidt crschmidt at crschmidt.net
Fri Jul 7 17:51:55 EDT 2006
On Sat, Jul 08, 2006 at 07:41:57AM +1000, Cameron Shorter wrote:
> Steve Lime wrote:
> <snip>
> >One question in my mind is what all the talk of project merging
> >(OpenLayers, ka-map,
> >MapBuilder and so on) really means. Is there a chance that in the near
> >future there really will be a single project comprised of the best of all
> >of the participating client
> >environments, and if so then how should that be taken into account as part
> >of incubation. Do we graduate a project that may substantial change near
> >term? If
> >projects do merge and one is "officially OSGeo" is the merged project now
> >official?
> >I know you've started those discussions but it's not clear where they sit.
> Steve,
> Mapbuilder are likely to start using OpenLayers as a rendering engine,
> which will effectively mean Mapbuilder would be using OpenLayers as a
> library.  So technically, we would be able to be an OSGeo member without
> bringing OpenLayers in as an OSGeo member.
I think that this will be the ideal situation for Mapbuilder and for
OpenLayers in this situation -- Any changes to move towards further
integration with OpenLayers will be in the form of using OpenLayers as a
library while still having Mapbuilder as a  seperately developed
project.
This may be the case for more tools which currently use a self-spanwed
map rendering engine: the core application would stay the same, but
OpenLayers would act as a renderer for the image data delivered from the
server.
Given this, I do not think that there is any concern with MapBuilder no
longer be a viable project within OSGeo: Mapbuilder has, and will
continue to, act as an application framework around a map renderer. It's
simply possible that OpenLayers will take over the 'map renderer' aspect
of MapBuilder at some point in the future.
Christopher Schmidt
Web Developer
More information about the Webmap-discuss mailing list
