[webmap-discuss] Client side coordinate transformation library - Call to developers/testers
Aaron Koning
aaronkoning at gmail.com
Tue Jul 25 17:41:22 EDT 2006
Hi Richard,
Its good to hear from you again. I am mostly interested in porting GCTP to
JavaScript. I have not had much use for datum conversions on the client
side, but I'd be interested to hear from anyone who has. Right now the
GCTP-JS port has the three most important projections for my region (Albers,
Lambert, UTM) and it works very well, so I am hesitant to get involved with
recreating this functionality. In addition, I believe that the GCTP can be
ported much quicker than Proj4 since it has less than half the files of
Proj4 and since many of the GCTP files contain only a few lines that need to
be converted. Perhaps there are more compelling reasons to redirect efforts?
Aaron
On 7/25/06, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> On 7/24/06, Aaron Koning <aaronkoning at gmail.com> wrote:
> > Hello All,
> > A while ago I created a client side coordinate transformation library
> called
> > GCTP-JS (Open Source, GPL licence). More accurately, I ported files
> directly
> > from the General Cartographic Transformation System (GCTP) C-code to
> > JavaScript.
> > http://datashare.gis.unbc.ca/gctp-js/
> > Simple example application:
> > http://datashare.gis.unbc.ca/gctp-js/examples.php
> > Implemented easily and successfully in the Flexible Internet Spatial
> > Template (FIST) web mapping application:
> > http://fist-mapping.org
> > Currently the 'port' is not complete (UTM, Albers, and Lambert
> projection
> > files have been ported). What I would like to see is a complete port of
> the
> > GCTP to JavaScript. Porting each projection file takes a few hours to a
> few
> > days depending on experience level (pretty quick I think). Then the
> > projection file must be tested, which is best done by someone who uses
> that
> > particular projection often.
> > The best reasons to get involved are:
> > - porting and testing can be done file by file;
> > - porting a file doesn't take very long;
> > - only work on the projections you want or the whole library;
> > - very little planning is needed since it is a straightforward
> porting
> > exercise;
> > - there is a definite and achievable end goal!
> > Therefore, I would like all interested parties to contact me at the
> address
> > below and start porting and testing projection files as soon as
> possible. I
> > am eager to get going and help make this a success!
> > The GCTP C-code can be downloaded at:
> > http://edcftp.cr.usgs.gov/pub//software/gctpc/gctpc_src.tar
> > Thank you for your time,
> > Aaron
> > | Aaron Koning
> > | Information Technologist
> > | Prince George, BC, Canada.
> > | http://datashare.gis.unbc.ca/fist/
> Aaron,
> We must be on the same wavelength! Just yesterday I sent an eamil to a
> couple lists regarding the work that I have been doing toward porting
> the Proj.4 cs2cs program to Javascript.
> I went with Proj.4 over GCTP primarily because Proj.4 has support for
> datum transformations. Is the GCTP license Open Source?
> Would you be interested in combining our projects?
> Rich
> Richard Greenwood
> www.greenwoodmap.com
| Aaron Koning
URL: http://lists.osgeo.org/pipermail/webmap-discuss/attachments/20060725/a73c9f46/attachment.html
More information about the Webmap-discuss
