[ZOO-Discuss] ZOO OGR Demo
Gérald Fenoy
gerald.fenoy at geolabs.fr
Thu Nov 12 07:05:29 PST 2009
Hi ZOO Tribe Members,
a new demo will be available soon, including Union, Intersection,
Difference and SymDifference which has been included this afternoon
into the ZOO ServiceProvider OGR based Sample.
Best regards,
Le 12 nov. 2009 à 13:09, Gérald Fenoy a écrit :
> I forgot to mention but it is obvious that you could choose also
> your output format for RawDataOutput if needed.
> Kind regards,
> Le 12 nov. 2009 à 13:03, Gérald Fenoy a écrit :
>> Hi Guillaume,
>> as you can choose the DataInput type you could also use a specific
>> output format, you only have to describe what is e desired output
>> format you want (the same KVP syntax than the one used for
>> DataInputs).
>> You'll find in the following some requests samples using KVP for
>> GET HTTP METHOD :
>> * sample using the JSON as output in ResponseDocument :
>> => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=application/json
>> * sample using the GML geeometry section in ResponseDocument :
>> => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/xml
>> * sample using unsupported output format (so the default output
>> will be used) :
>> => http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Centroid&DataInputs=InputPolygon=Reference@xlink:href=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.31&ResponseDocument=Result@mimeType=text/html
>> So you could define what are the inputs type and what should be the
>> output one :)
>> Hope this was clear enough and answer you question.
>> Let me know,
>> regards,
>> Le 11 nov. 2009 à 22:04, Guillaume Sueur a écrit :
>>> is json chosen automatically from http user-agent then ? WPS is
>>> not only
>>> a browser service. so there should be a way to specify the desired
>>> output format.
>>> Le mercredi 11 novembre 2009 à 22:00 +0100, rldhont a écrit :
>>>> I think it's coll to use GML and have a JSON because GML sucks in
>>>> a browser.
>>>> Well it's my point of view.
>>>>> Cool !
>>>>> but as Eric mentionned previously, I don't understand either why a
>>>>> WFS/GML geometry for input gets a geojson for output. Nothing
>>>>> seems to
>>>>> specify it in the request. I think the format should be consistant
>>>>> between input and output unless requested different.
>>>>> Thanks for your efforts in putting together this first demo.
>>>>> Regards
>>>>> Guillaume
>>>>> Le mercredi 11 novembre 2009 à 21:20 +0100, rldhont a écrit :
>>>>>> Hi all,
>>>>>> I'm glad to annonce a new version of ZOO OGR Demo :
>>>>>> http://demo.zoo-project.org/ogr/ogr-wfs-demo.html
>>>>>> This one is fully integrated with the ZOO project design and
>>>>>> add 1 new
>>>>>> capability : choose a distance for the buffer processing.
>>>>>> Enjoy!
>>>>>> René-Luc D'Hont
>>>>>> 3Liz
>>>>>> _______________________________________________
>>>>>> Zoo-discuss mailing list
>>>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
>> GEOLABS
>> Siège social :
>> Futur Building I
>> 1280, avenue des Platanes
>> 34970 Lattes
>> Tél. fixe : 04 67 53 67 37
>> Tél. portable : 06 70 08 25 39
> Gérald Fenoy
> GEOLABS
> Siège social :
> Futur Building I
> 34970 Lattes
Gérald Fenoy
GEOLABS
Siège social :
Futur Building I
34970 Lattes
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20091112/13e12dc2/attachment.html>
More information about the Zoo-discuss
