[ZOO-Discuss] ZOO Web Client ideas
jachym.cepicky at gmail.com jachym.cepicky at gmail.com
Fri Nov 13 06:42:45 PST 2009
On Fri, Nov 13, 2009 at 02:14:14PM +0100, Gérald Fenoy wrote:
> Hi Jachym,
> could I know if your WPS Client is able to produce dynamically HTML
> Forms (which could become realy complexe) and activate/add the
> appropriate tool to feed the process inputs ?
> Did you already tried something like this ?
yes
pywps/trunk/doc/examples/clients/wps-WPS.html (possible broken, but the
idea is there)
> Maybe we could think it's a hard task to produce dynamicaly forms
> and activated the appropriate tool (to produce/select a geometry for
> instance) this way, but IMO the more generic the Client Side is
> better it is.
> I know that the hardest part is for selecting / producing tool
> selection. But why can't we already think of some basic examples of
> automaticaly selected select/add/edit tool and then when the
> "process-feeder" Class is instantiated we can pass it what behavior
> we want to activate.
impossible, the server could define metadata to each process
input/output and the client could generate the proriate tool for it.
I was proposing this many times in various mailing lists,
jachym
> A Behavior could be a JS function which activate for the user the
> appropriate tool for building his own new geometry, the behavior
> could be as simple as the selectFeature used in the demo page. Then
> when the web site developer code his page he only have to decide
> which tool to activate (or to add if the tool is specific to this
> process).
> Maybe we can even ask the user when he wants to run a process :
> "Please user, which tool do you wants to use to feed the first
> Geometry ?". This way, the user is free to make his own choice and
> we let the web client developer far from that kind of
> consideration...
> Nevertheless, I want to say that if we can get something similar to
> MacOS X Automator on the web, which sounds something similar to the
> ZOO Logic idea, to create processes it could be great.
> Just a note to tell that in Automator, they produce the forms in a
> dynamic way using something similar to the result of
> DescribeProcess.
> I invite everybody to test Automator  and think about the same thing
> in a web interface. Is that an impossible task to put something
> similar on the web ? IMO no :)
> Let me know what do you think Members.
> Hope to hear from you,
> Le 13 nov. 2009 à 13:21, Jachym Cepicky a écrit :
> >hi, again,
> >On Fri, Nov 13, 2009 at 11:33:35AM +0100, rldhont wrote:
> >>Eric Lemoine a écrit :
> >>>On Friday, November 13, 2009, rldhont <rldhont at gmail.com> wrote:
> >>>>Hi All,
> >>>>I think DescribeProcess could be use to create object to control
> >>>>mandatory parameters, datatypes and mimetypes. It will be
> >>>>usefull, isn't
> >>>>it ?
> >>>sorry I don't get what you mean. Could you elaborate a bit please?
> >>>Thanks,
> >>In a describe process, we could find parameter's name, parameter's
> >>mandatory, parameter's datatype or mimetype.
> >>Based on a describeProcess, it's possible to construct a JavaScript
> >>Object which could validate a process request. I think
> >>DescribeProcess
> >>must be used to do this.
> >yes, this is all solved in the WPS.js comming with PyWPS. But I would
> >like to, if somebody would help with it's development
> >Jachym
> >Jachym Cepicky
> >e-mail: jachym.cepicky gmail com
> >URL: http://les-ejk.cz
> >GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
> >Key fingerprint: 0C6D 0EAE 76BD 506C F299  ED8A C8AB 74B8 08D4 E08F
> >_______________________________________________
> >Zoo-discuss mailing list
> >Zoo-discuss at gisws.media.osaka-cu.ac.jp
> >http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Djay
> Just a ZOO Monkey
> gerald.fenoy at geolabs.fr
Jachym Cepicky
e-mail: jachym bnhelp cz
URL: http://bnhelp.cz
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20091113/8b688a38/attachment.pgp>
More information about the Zoo-discuss mailing list
