[ZOO-Discuss] GRASS WPS Process Description
rldhont
rldhont at gmail.com
Fri Nov 27 00:14:34 PST 2009
Hi ZOO-tribe
Yesterday on IRC, Soeren explains that:
"He has implemented WPS process description document generation into
grass. Now each grass module is able to create its own specific WPS
process description. These WPS XML documents can now be used with WPS
server. Any GRASS module implemented in C, C++, Shell, Python or Java
(in the future) will support this feature ... with some limitations."
The Soeren's question is:
"Does the zoo-kernel support the configuration via WPS XML process
description document?"
And Soeren adds this:
"Next step is to provide a python module which does all the conversion,
reprojection and grass computation stuff, which is needed to run a grass
module. Then connecting GRASS to zoo-kernel, 52N and deegree will be a
piece of cake."
Well Gérald, What do you think about it ? Do you have to create a GRASS
Provider, like C or Python ? How to re-use this capability ?
René-Luc D'Hont
3Liz
More information about the Zoo-discuss
