[ZOO-Discuss] libjs
david saggiorato david at saggiorato.net
Tue Apr 20 03:28:28 PDT 2010
Hi
I fixed the problem in the configure.ac, for compilation under
debian/ubuntu  you should use the package libmozjs-dev and add - with-js as
a configuration option.
Regards
David
ps: I have attached the corrected file
2010/4/19 Daniel Kastl <daniel at georepublic.de>
> That would be nice, because being able to use packages makes it much easier
> to install (and to remove/upgrade).
> I think I also stopped installation there, because I run into the same
> issue.
> Daniel
> 2010/4/19 Gérald Fenoy <gerald.fenoy at geolabs.fr>
> Hi,
>> René-Luc was right, in fact we are waiting for answering more precisely to
>> you as we only compile against SpiderMonkey manually compiled and installed.
>> David Saggiorato is currently on the way to make tests and modifications (if
>> needed) to the configure.ac file. Hope we don't make to much time to
>> answer you clearly if you can compile against the debian package install
>> without any modification or using some patches.
>> We will inform you  as soon as possible,
>> regards,
>> Le 19 avr. 2010 à 14:01, René-Luc D'Hont a écrit :
>> > I think, Gérald'll correct me, that the libjs you search for the
>> > compilation is SpiderMonkey. On Ubuntu there is a package with
>> > SpiderMonkey. SpiderMonkey provide a jsapi.h used in ZOO.
>> > Regards
>> > René-Luc D'Hont
>> > Le 19/04/2010 11:26, Luca Delucchi a écrit :
>> >> I everybody, i'll try to compile zoo on ubuntu/debian with all
>> >> dependecies to create a page on the trac but if i try to compile with
>> >> js it don't found the libjs. I don't understand what i must install
>> >> for libjs, because in the packages [0][1] i found some libjs but are
>> >> other softwares like jquery, prototype, etxjs ecc ecc
>> >> regards
>> >> Luca
>> >> [0]
>> http://packages.debian.org/search?keywords=libjs&searchon=names&suite=stable&section=all
>> >> [1]
>> http://packages.ubuntu.com/search?keywords=libjs&searchon=names&suite=karmic&section=all
>> >> _______________________________________________
>> >> Zoo-discuss mailing list
>> >> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> >> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>> Djay
>> Just a ZOO Tribe Member
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100420/8b64fee0/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100420/8b64fee0/attachment.obj>
More information about the Zoo-discuss mailing list
