[ZOO-Discuss] libjs
Daniel Kastl
daniel at georepublic.de
Mon Apr 19 06:33:28 PDT 2010
That would be nice, because being able to use packages makes it much easier
to install (and to remove/upgrade).
I think I also stopped installation there, because I run into the same
issue.
Daniel
2010/4/19 Gérald Fenoy <gerald.fenoy at geolabs.fr>
> Hi,
> René-Luc was right, in fact we are waiting for answering more precisely to
> you as we only compile against SpiderMonkey manually compiled and installed.
> David Saggiorato is currently on the way to make tests and modifications (if
> needed) to the configure.ac file. Hope we don't make to much time to
> answer you clearly if you can compile against the debian package install
> without any modification or using some patches.
> We will inform you as soon as possible,
> regards,
> Le 19 avr. 2010 à 14:01, René-Luc D'Hont a écrit :
> > I think, Gérald'll correct me, that the libjs you search for the
> > compilation is SpiderMonkey. On Ubuntu there is a package with
> > SpiderMonkey. SpiderMonkey provide a jsapi.h used in ZOO.
> > Regards
> > René-Luc D'Hont
> > Le 19/04/2010 11:26, Luca Delucchi a écrit :
> >> I everybody, i'll try to compile zoo on ubuntu/debian with all
> >> dependecies to create a page on the trac but if i try to compile with
> >> js it don't found the libjs. I don't understand what i must install
> >> for libjs, because in the packages [0][1] i found some libjs but are
> >> other softwares like jquery, prototype, etxjs ecc ecc
> >> regards
> >> Luca
> >> [0]
> http://packages.debian.org/search?keywords=libjs&searchon=names&suite=stable§ion=all
> >> [1]
> http://packages.ubuntu.com/search?keywords=libjs&searchon=names&suite=karmic§ion=all
> >> _______________________________________________
> >> Zoo-discuss mailing list
> >> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> >> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Djay
> Just a ZOO Tribe Member
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100419/8b768556/attachment.html>
More information about the Zoo-discuss
