[ZOO-Discuss] libjs
Gérald Fenoy
gerald.fenoy at geolabs.fr
Mon Apr 19 06:28:39 PDT 2010
René-Luc was right, in fact we are waiting for answering more precisely to you as we only compile against SpiderMonkey manually compiled and installed. David Saggiorato is currently on the way to make tests and modifications (if needed) to the configure.ac file. Hope we don't make to much time to answer you clearly if you can compile against the debian package install without any modification or using some patches.
We will inform you as soon as possible,
regards,
Le 19 avr. 2010 à 14:01, René-Luc D'Hont a écrit :
> I think, Gérald'll correct me, that the libjs you search for the
> compilation is SpiderMonkey. On Ubuntu there is a package with
> SpiderMonkey. SpiderMonkey provide a jsapi.h used in ZOO.
> Regards
> René-Luc D'Hont
> Le 19/04/2010 11:26, Luca Delucchi a écrit :
>> I everybody, i'll try to compile zoo on ubuntu/debian with all
>> dependecies to create a page on the trac but if i try to compile with
>> js it don't found the libjs. I don't understand what i must install
>> for libjs, because in the packages [0][1] i found some libjs but are
>> other softwares like jquery, prototype, etxjs ecc ecc
>> regards
>> Luca
>> [0] http://packages.debian.org/search?keywords=libjs&searchon=names&suite=stable§ion=all
>> [1] http://packages.ubuntu.com/search?keywords=libjs&searchon=names&suite=karmic§ion=all
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Djay
Just a ZOO Tribe Member
More information about the Zoo-discuss
