[ZOO-Discuss] Wanna test the ZOO JavaScript Support
René-Luc D'Hont
rldhont at gmail.com
Tue Feb 23 14:07:56 PST 2010
If you wanna test the ZOO JavaScript support, you can do it here :
http://shilpa.media.osaka-cu.ac.jp/demo/test_services_post_jsr.html
You can use this XML :
<wps:Execute service="WPS" version="1.0.0"
xmlns:wps="http://www.opengis.net/wps/1.0.0"
xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wps/1.0.0/../wpsExecute_request.xsd">
<ows:Identifier>EvaluateJS</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>Code</ows:Identifier>
<wps:Data>
<wps:ComplexData mimeType="text/plain">
<![CDATA[
</wps:ComplexData>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput>
<ows:Identifier>Result</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
And set the Code input with JavaScript Code!
For helping you here an example:
var process = new ZOO.Process('http://localhost/zoo/','Union');
var inputs1 = {
InputEntity1:{type:'reference',value:'http://demo.opengeo.org/geoserver/ows?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&typename=topp:states&SRS=EPSG:4326&FeatureID=states.45'},
InputEntity2:{type:'complex',mimetype:'application/json',value:'{"type":"Polygon","coordinates":[[[-111.07132,31.335535],[-114.820969,32.487114],[-114.735397,35.987667],[-114.727333,36.085983],[-114.043137,36.996563],[-110.483398,37.003929],[-109.047821,36.996643],[-109.045998,34.954613],[-109.045006,31.343348],[-110.451942,31.337559],[-111.07132,31.335535]]]}'}
var str = process.Execute(inputs1);
return {value:str,mimeType:'text/plain'};
And an other one:
var str = ZOO.Request.Get('http://demo.opengeo.org/geoserver/ows',
{SERVICE:'WFS',
REQUEST:'GetFeature',
VERSION:'1.0.0',
typename:'topp:states',
SRS:'EPSG:4326',
FeatureID:'states.45'});
var gml = new ZOO.Format.GML();
var features = gml.read(str);
var geojson = new ZOO.Format.GeoJSON();
str = geojson.write(features);
var kml = new ZOO.Format.KML();
str = kml.write(features);
You can define more than 1 input, for example with this XML :
<wps:DataInputs>
<wps:Input>
<wps:Data>
<![CDATA[
</wps:ComplexData>
</wps:Data>
</wps:Input>
<wps:Input><ows:Identifier>InputEntity1</ows:Identifier><wps:Reference
mimeType="text/xml"
xlink:href="http://demo.opengeo.org/geoserver/ows?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&typename=topp:states&SRS=EPSG:4326&FeatureID=states.45"/></wps:Input><wps:Input><ows:Identifier>InputEntity2</ows:Identifier><wps:Data><wps:ComplexData
mimeType="application/json">
</wps:ComplexData></wps:Data></wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
Which mean that you can test your own process with your input and your
code process. You can test the disponible inputs with this code :
var str = aInputs.length+'\n';
for (var key in inputs) {
str += key+'\n';
for (var i=0, len=aInputs.length; i<len; i++) {
var input = aInputs[i];
for (var key in input) {
str += key+'\n';
Or with the other one :
function dump(){
var str = '';
for (var key in arguments[0]) {
for(var key1 in arguments[0][key]){
str += '**********************************\n';
str += key1+'\n**********************************\n';
for(var key2 in arguments[0][key][key1])
str += key2+' <=> '+arguments[0][key][key1][key2]+'\n';
return str;
var aconf=dump(aConf);
var ainputs=dump(aInputs);
var aoutputs=dump(aOutputs);
return
{value:aconf+"\n\n"+ainputs+"\n\n"+aoutputs,mimeType:'text/plain'};
Enjoy!
René-Luc D'Hont
3Liz
More information about the Zoo-discuss
