[ZOO-Discuss] GIS GRASS ZOO integration
Eugenio Realini
eugenio.realini at gmail.com
Sat Oct 9 08:53:06 PDT 2010
Hi Soeren,
thanks for your reply!
2010/10/9 Soeren Gebbert wrote:
> try to add:
> grass_band_number=1
> to your request to specify a band number for processing. It seems that
> the ZOOGrassModuleStarter expects an integer value or None as default
> value from the zoo_loader, not 'NULL' which is C-specific.
>From our DescribeProcess it seems that the only input parameter
r_univar accepts is "map":
http://131.175.143.108/cgi-bin/zoo_loader.cgi?Service=WPS&Request=DescribeProcess&Version=1.0.0&Identifier=r_univar
Now I do not have its xml and zcfg files to check, but if I don't
remember wrong there should have been a parameter like
"grass_band_number"...
Actually we have a similar problem also with r.horizon. We created the
GRASS XML file, generated the zcfg and python files from it and added
the service to ZOO (after changing some square brackets to normal ones
in the Titles, otherwise ZOO got messed up).
The problem is that the DescribeProcess shows only two inputs
(http://131.175.143.108/cgi-bin/zoo_loader.cgi?Service=WPS&Request=DescribeProcess&Version=1.0.0&Identifier=r_horizon),
despite having a lot more in the zcfg file
(http://pastebin.com/TTNfRQ99). It seems that ZOO keeps only the
"ComplexData" ones and discards the "LiteralData" ones.
I really do not have any idea about what could be the problem.
Ege
More information about the Zoo-discuss
