[ZOO-Discuss] some problems with the zoo-services examples
Marco Negretti
marco.negretti at polimi.it
Fri Oct 22 07:27:59 PDT 2010
I installed the Zoo kernel and I guess that it works... the hello-py
example works.
I'm trying to use the other examples in zoo-services dir but I had some
problems:
=== gdal/translate ===
I can't compile the service: when I launch the make command I have many
warning messages and this error message:
./service.c:135: error: 'mtoupper' was not declared in this scope
Some ideas?
ogr/ogr2ogr
I compiled the code and copied in my web server zoo dir
Ogr2Ogr.zcfg and ogr_2_ogr_service.zo
I think that the Ogr2Ogr.zcfg is wrong:
for example,
line 1: Title = Convert raster data from one format to another.
line 21: (type of data input) : value = AAIGrid (Arc/Info ASCII Grid)
...and some other...
Isn't it a process for vector conversion?
I rewrited the Ogr2Ogr.zcfg, but the service doesn't work:
<wps:ProcessFailed>
<ows:ExceptionReport xml:lang="en-US" version="1.1.0">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>No more information
available</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
</wps:ProcessFailed>
It's possible that I made some errors in my zcfg file, but... "No more
information available"
Did someone try to use this examples?
=== ogr/base-vect-ops ===
I compiled the code and copied in my web server zoo dir Buffer.zcfg and
ogr_service.zo.
The service work properly, I send as input a WFS map with one polygon
and the service calculates the buffer, but the output is a .js file.
This is a part of service response:
<wps:ProcessOutputs>
<wps:Output>
<ows:Identifier>Result</ows:Identifier>
<ows:Title>Buffered Polygon</ows:Title>
<ows:Abstract>
GML stream describing the buffered polygon feature.
</ows:Abstract>
<wps:Reference href="http://localhost/tmp/Buffer_130521.js"
mimeType="text/plain" encoding="UTF-8"/>
</wps:Output>
</wps:ProcessOutputs>
and this is an extract of the file .js with the buffer coordinates:
{ "type": "Polygon", "coordinates": [ [ [ 307875.325459, 5360132.252371
], [ 307311.888640, 5360142.807357 ], [ 307309.284548, 5360142.924101 ],
[ 307835.808046, 5358896.308003 ], [ 307875.325459, 5360132.252371 ] ] ] }
How can I get a gml file as output?
Thanks,
Marco
Marco Negretti
Politecnico di Milano - Polo Regionale di Como
email: marco.negretti at polimi.it
http://geomatica.como.polimi.it/
_________________________________________________________
http://www.gnu.org/philosophy/no-word-attachments.it.html
More information about the Zoo-discuss
