[ZOO-Discuss] ZOO Debian Package
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Tue Sep 21 19:53:00 PDT 2010
Hi Alessandro,
ZOO understands WPS spoken in many programming languages
such as C/C++, Python, Fortran, Java, Python etc.
In future ZOO may understand more than just WPS talked
in different programming languages. In fact ZOO can be
used for non-geospatial Processing services too.
I also agree with Daniel that it would be better to
package "zoo-kernel", "zoo-services" and "zoo-api"
into one bundle to make thinks easier.
So naming something like zoo-wps-x.x.x for the
package is fine with me.
I would also like to suggest zoo-kasa-x.x.x, zoo-wps-kasa-x.x.x
or zoowps-kasa-x.x.x.
Kasa in Japanese means umbrella and could stand for
Kernel-API-Service-Applications.
or
zoo-ask-x.x.x, zoo-wps-ask-x.x.x
or zoowps-ask-x.x.x.
with ASK standing for API, Service and Kernel
Best
Venka
Daniel Kastl wrote:
> Hi Alessandro and others,
> I think that splitting ZOO into multiple packages must make sense for a
> user, for example when someone only wants to install the basics on a
> production server.
> But it should be already clear from the configure - make - install process.
> So if you build several packages "zoo-kernel", "zoo-services" and "zoo-api"
> for example and you have to write custom scripts to pick one part from here
> and one from there, this wouldn't be a good idea IMO.
> So if ZOO-Project is already designed that it wants to make certain parts
> optional (or will do in the future), then it makes sense to split packages,
> otherwise not.
> Daniel
> PS: I would prefer some anming like zoo-<name>-x.x.x if this is not against
> some naming convention
> 2010/9/21 Alessandro Frigeri <alessandro.frigeri at gmail.com>
>> Hi,
>> thanks for all the suggestions. Yesterday I've worked at a simple
>> version of the package that will carry zoo_loader.cgi in the cgi-bin
>> dir and main.cfg in the examples directory, plus all the standard
>> debian files. The good thing is that the packaging build process
>> seems to work quite well, and that's good for porting it to different
>> architectures.
>> For the name of the package, from the discussion it seems that we have
>> to chose from two options:
>> zoowps-x.x.x - this is the case if zoo will always talk 'wps'
>> zookernel-x.x.x - if 'wps' is just one of the 'languages' zoo will
>> talk with clients in future (as I understood from Venka's message),
>> and the 'kernel' is to be considered the engine where to attach
>> services communicating with 'languages' other than wps (are there
>> other ones around yet?).
>> Regarding the future addons, debian/ubunt provides the
>> "packagename-extras" naming scheme option that fits well with our case
>> for extra backends.
>> I don't want to be too pedant on this, since it is only a name, but
>> choosing a good package name will save time later on.
>> Alessandro
>> 2010/9/21 Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp>:
>>> Someday ZOO could hopefully be more than WPS
>>> only.
>>> My suggestion would be to name the package as
>>> zoo-kernel with subsequent release zoo-services
>>> and zoo-api.
>>> Since multi-language support is one of the
>>> main features of the ZOO-Kernel, the present release
>>> (ZOO-Kernel-1.0.1) could C/C++, Fortran and Python
>>> support. Future stable release (ZOO-Kernel-1.2.X) could
>>> include support for javascript and other newly
>>> supported languages.
>>> ZOO-Services and ZOO-API could be released as independent
>>> packages.
>>> Also a possibility of releasing ZOO-Bundle (which includes
>>> ZOO-Kernel, ZOO-Services and ZOO-API) in the future.
>>> Best
>>> Venka
>>> On 2010/09/20 22:15, Gérald Fenoy wrote:
>>>> Hi Daniel, yes you're right, maybe better to keep WPS in the package
>>>> name.
>>>> I agree also that the zoo-service and zoo-api can be installed as
>>>> independent packages. But if we use it this way, then how can we
>>>> provide the ZOO Kernel ? I mean that the compilation process of the
>>>> ZOO Kernel imply that each requested Languages support have to be
>>>> compiled at the same time. Or do we need to plan to provide multiple
>>>> "zoo-wps" packages for each support ? I mean something like :
>>>> zoo-wps-std for ZOO Kernel with C/C++, Fortran and Python support,
>>>> then zoo-wps-javascript for another one including the later and with
>>>> the javascript addition and so on ?
>>>> I don't know how to do this in an efficient way.
>>>> Let me know what you think, Regards,
>>>> Le 20 sept. 2010 à 14:39, Daniel Kastl a écrit :
>>>>> Hi Gerald,
>>>>> Is ZOO-Project going to be more than WPS? Alessandro's proposal
>>>>> idea to call it "zoo-wps" isn't bad IMO. Another idea would be - in
>>>>> case ZOO Services and API could be installed extra - to split them
>>>>> in packages like "zoo-kernel", "zoo-services", "zoo-api" with being
>>>>> "zoo-kernel" required for others.
>>>>> Well, shouldn't become to complicated on the other hand.
>>>>> Daniel
>>>>> 2010/9/20 Gérald Fenoy<gerald.fenoy at geolabs.fr> Hi Alessandro, nice
>>>>> to hear from you.
>>>>> I think it can be better to use ZOO-Project, if this is acceptable
>>>>> in Debian packaging name. If not then maybe you can use
>>>>> zoo-project.
>>>>> We will create a branch and tag officially in some days, we need to
>>>>> finalize the Perl support integration first. It was currently
>>>>> tested by David Saggiorato on his own (some part was already
>>>>> integrated in the SVN source tree). We also need to add a ZOO
>>>>> Service Provider which will access some shared memory to get
>>>>> information on the current status of a process. I think that those
>>>>> two enhancement can be finalized really soon and then we can tag as
>>>>> 1.0.1 version. Other plan for the 2.0 version will start next week,
>>>>> it will include the modification of service functions signature,
>>>>> the main reason for creating a new version.
>>>>> Please use the SVN source tree and not the archive 1.0 you talked
>>>>> about, indeed we have to provide the new version of the archive
>>>>> soon for the new version present in SVN.
>>>>> If you need the branch quickly please let me know, we will create
>>>>> it faster than we planned to do.
>>>>> Hope to hear from you, best regards,
>>>>> Le 20 sept. 2010 à 13:22, Alessandro Frigeri a écrit :
>>>>>> Hei Nick, Venka + zooers,
>>>>>> thanks for the details. Sorry, I've missed the 1.0 was there
>>>>>> already there,
>>>>>> http://www.zoo-project.org/dl/ZOO-Kernel-1.0.tar.bz2, i'll submit
>>>>>> un update to our request to debian.
>>>>>> Also, I've found there is already a package named "zoo", to
>>>>>> manipulate zoo archives. So we can go with with "zoowps"
>>>>>> "zoo-wps" or whatever is good to differentiate from the other
>>>>>> package. Suggestions are welcome so we can start up in good
>>>>>> shape with debian and the ubuntu packages.
>>>>>> For the version scheme, it seems ok to me. Nick, let's
>>>>>> experiment an svn copy trunk to some 1.0.x tag.
>>>>>> Alessandro
>>>>>> 2010/9/20 Venkatesh Raghavan<raghavan at media.osaka-cu.ac.jp>:
>>>>>>> Hi Alessandro,
>>>>>>> Thanks for the follow-up at debian/ubuntu miniconf regarding
>>>>>>> ZOO
>>>>>>> I think ZOO could follow the similar scheme as GRASS GIS as
>>>>>>> below;
>>>>>>> Version number scheme:
>>>>>>> * first number: major release number * secondary number: minor
>>>>>>> release number (stable/development indicator) * third number:
>>>>>>> revision
>>>>>>> Scheme for ZOO-Kernel 1.0.1 which is presently available would
>>>>>>> be as follows
>>>>>>> a) 1 being the major release number b) 0 being the minor
>>>>>>> release number c) 1 being the revision
>>>>>>> Any suggestions from others?
>>>>>>> Best
>>>>>>> Venka
>>>>>>> On 2010/09/20 6:00, nicolas bozon wrote:
>>>>>>>> Hi Alessandro,
>>>>>>>> Thanks for the request to Debian ! ZOO Kernel was released on
>>>>>>>> April 2010 under 1.0 version. We are now under the 1.0.1
>>>>>>>> since last week, as the svn was updated with new version by
>>>>>>>> gerald I think we still have to improve the branching, you're
>>>>>>>> right. Best,
>>>>>>>> Nick
>>>>>>>> 2010/9/19 Alessandro Frigeri<afrigeri at unipg.it>
>>>>>>>>> Hi zooers,
>>>>>>>>> The debian/ubuntu mini conf was very fruitful - nice ideas
>>>>>>>>> and nice people. For zoo, I've placed a request on
>>>>>>>>> debian:
>>>>>>>>> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=597445
>>>>>>>>> Are you guys going to tag a release (e.g. 1.0 or whatever
>>>>>>>>> call a major/minor version)? It will be a lot easier to
>>>>>>>>> refer the package to a tagged version (and produce package
>>>>>>>>> files accordingly).
>>>>>>>>> Ciao!
>>>>>>>>> Alessandro
>>>>>>>>> 2010/9/17 Venkatesh
>>>>>>>>>> Hi Alessandro,
>>>>>>>>>> Was great meeting you in Barcelona. Gerald, David and
>>>>>>>>>> Yoshida have trying to make the Debian package from
>>>>>>>>>> ZOO-Kernel.
>>>>>>>>>> Maybe you can help us. Also, please consider joining the
>>>>>>>>>> ZOO-Discuss ML.
>>>>>>>>>> Best
>>>>>>>>>> Venka
>>>>>>>>> -- Alessandro Frigeri, PhD
>>>>>>>>> _______________________________________________ Zoo-discuss
>>>>>>>>> mailing list Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>>>>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>>>>>>>> Zoo-discuss mailing list
>>>>> Gérald Fenoy ZOO PSC Chair gerald.fenoy at geolabs.fr
>>>>> _______________________________________________ Zoo-discuss mailing
>>>> Gérald Fenoy gerald.fenoy at geolabs.fr
More information about the Zoo-discuss
