[ZOO-Discuss] API license
nicolas bozon
nicolas.bozon at gmail.com
Tue Apr 5 03:26:52 PDT 2011
Hello again Bart, all
After this morning modifications, I am now wondering about the license used
for the ZOO API.
As you may have noticed, the whole ZOO Project is licensed under the MIT
license.
As we are using parts of the OL code, does that mean that we should switch
from MIT to BSD ?
Same thing for proj4js, from MIT to LGPL ?
Many thanks for any hint.
Best,
Nick
2011/4/5 nicolas bozon <nicolas.bozon at gmail.com>
> Hi Bart,
> Thank you very much for pointing out this issue.
> The ZOO API files were just corrected.
> The OpenLayers copyright was added as you suggested, under our original
> copyright block:
> http://www.zoo-project.org/trac/browser/trunk/zoo-api/js/ZOO-api.js
> The Proj4js authors and license were also added here:
> http://www.zoo-project.org/trac/browser/trunk/zoo-api/js/ZOO-proj4js.js
> Thanks again and see you in Denver i guess !
> Best,
> Nick
> 2011/4/4 Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>
> Hey Zoo-tribe,
>> the code in ZOO-api.js clearly contains some copies of parts of the
>> OpenLayers code, but where is the OpenLayers copyright? Can you please add
>> this somewhere?
>> TIA.
>> Best regards,
>> Bart
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110405/cf3a3865/attachment.html>
More information about the Zoo-discuss
