[ZOO-Discuss] API license
Bart van den Eijnden
bartvde at osgis.nl
Tue Apr 5 03:33:39 PDT 2011
Hi Nick,
I am no expert on licensing.
Chris, any chance you can shed some light on this? TIA.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Apr 5, 2011, at 12:26 PM, nicolas bozon wrote:
> Hello again Bart, all
> After this morning modifications, I am now wondering about the license used for the ZOO API.
> As you may have noticed, the whole ZOO Project is licensed under the MIT license.
> As we are using parts of the OL code, does that mean that we should switch from MIT to BSD ?
> Same thing for proj4js, from MIT to LGPL ?
> Many thanks for any hint.
> Best,
> Nick
> 2011/4/5 nicolas bozon <nicolas.bozon at gmail.com>
> Hi Bart,
> Thank you very much for pointing out this issue.
> The ZOO API files were just corrected.
> The OpenLayers copyright was added as you suggested, under our original copyright block:
> http://www.zoo-project.org/trac/browser/trunk/zoo-api/js/ZOO-api.js
> The Proj4js authors and license were also added here:
> http://www.zoo-project.org/trac/browser/trunk/zoo-api/js/ZOO-proj4js.js
> Thanks again and see you in Denver i guess !
> Best,
> Nick
> 2011/4/4 Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>
> Hey Zoo-tribe,
> the code in ZOO-api.js clearly contains some copies of parts of the
> OpenLayers code, but where is the OpenLayers copyright? Can you please add
> this somewhere?
> TIA.
> Best regards,
> Bart
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110405/486efed5/attachment.html>
More information about the Zoo-discuss
