[ZOO-Discuss] configure option "--with-python" went wrong
Elvis Wang
wbprime at gmail.com
Thu Apr 28 04:05:27 PDT 2011
Hi all,
I tried to compile the ZOO kernel in my Arch linux X64 platform. In fact I
don't want to enable the python support. So I just run ./configure using
bash. But after configuring, there came an error that shows "configure:
error: could not find python-config from libpython within the current
path. You may need to try re-running configure with a --with-python
parameter."
So I had to give the with-python option. I changed the configure file to
find the python2-config file in my system in /usr/bin for I Arch installed
python2.7 as default. It solved the problem by running "./configure
--with-python=/usr". But another problem is that "configure: error: the
user-specified php-config file /bin/php-config does not exist". I had not
installed PHP and I did't want to install it. What should I do to compile
zoo kernel directly?
Thanks in advance.
ELvis Wang
By Elvis Wang from Beijing, China. E-mail: wbprime at gmail.com
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110428/b85f1ae7/attachment.html>
More information about the Zoo-discuss
