[ZOO-Discuss] Error when running GRASS processes
Pierre Roudier
pierre.roudier at gmail.com
Thu Apr 28 23:09:30 PDT 2011
Thanks Soeren,
> The zoo services v_voronoi.py and v_delaunay.py must be present in
> /usr/lib/cgi-bin/ too.
> The minimum content of this directory should be:
> gms main.cfg v_delaunay.py v_delaunay.zcfg v_voronoi.py
> v_voronoi.zcfg ZOOGrassModuleStarter.py zoo_loader.cgi
Corrected that.
However, It still throws an error. Here's the apache log:
File "/usr/lib/cgi-bin/v_voronoi.py", line 4, in <module>
import ZOOGrassModuleStarter as zoo
File "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 24, in <module>
import GlobalGrassSettings
ImportError: No module named GlobalGrassSettings
error : file not found
> Yes, it is designed to run from the shell i.e:
> cd wps-grass-bridge/Testing/Python
> python SendRequests.py -f ExecuteRequests/v.voronoi.execute.xml -u
> "http://localhost/cgi-bin/zoo_loader.cgi"
Here's the error on the execution of that request:
root at grass:/usr/local/src/wps-grass-bridge-read-only/Testing/Python#
Start request 0
########### 0 ##########
<?xml version="1.0" encoding="utf-8"?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
<ows:Exception exceptionCode="InvalidParameterValue">
<ows:ExceptionText>The value for <indetifier> seems to be
wrong (v.voronoi). Please, ensure that the process exist using the
GetCapabilities request.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Cheers,
Pierre
> Best regards
> Soeren
>> Your help, and the efforts you are putting on open-source software,
>> is greatly appreciated.
>> Best,
>> Pierre
>>> Best regards
>>> Soeren
>>> 2011/4/28 Pierre Roudier <pierre.roudier at gmail.com>:
>>>> Dear zoo-keepers,
>>>> I'm trying the WPS GRASS bridge - unfortunately I can't make it work so far.
>>>> I've added two GRASS processes to my /usr/lib/cgi-bin:
>>>> root at grass:/usr/local/src/zoo/zoo-kernel# ls /usr/lib/cgi-bin/ | grep .zcfg
>>>> HelloPy.zcfg
>>>> v_delaunay.zcfg
>>>> v_voronoi.zcfg
>>>> The GetCapabilities is working fine. In QGIS, I'm using the WPS plugin
>>>> to try to make a Voronoi tesselation or a Delaunay triangulation of a
>>>> dummy points shapefile. In both cases, I got the following error when
>>>> running the process:
>>>> <ows:Exception exceptionCode="NoApplicableCode">
>>>> <ows:ExceptionText>Python module v_delaunay cannot be loaded.
>>>> </ows:Exception>
>>>> Any suggestion?
>>>> Cheers,
>>>> Pierre
>>>> Scientist
>>>> Landcare Research, New Zealand
>>>> _______________________________________________
>>>> Zoo-discuss mailing list
>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>> Scientist
Scientist
More information about the Zoo-discuss
