[ZOO-Discuss] [ZOO Project Trac] #15: ZOO API docs needed
ZOO Project Trac zoo-dev at cartography.st
Thu Apr 28 13:08:55 PDT 2011
  Reporter:  nickboz        |       Owner:  reluc
      Type:  enhancement    |      Status:  closed
  Priority:  major          |   Milestone:  1.2.0
 Component:  Documentation  |     Version:
Resolution:  fixed          |    Keywords:  ZOO API
Changes (by jmckenna):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 - all ZOO API classes are now documented: http://www.zoo-
 project.org/docs/api/classes.html
  - if you are using Adobe Reader you can also click on each Class in the
 pdf: http://www.zoo-project.org/docs/ZOOProject.pdf
  - marking as fixed
  - if any changes to any classes/functions/properties are made in the
 source, please file a ticket for each individual function or property
 change under the "Documentation" component in Trac
Ticket URL: <http://svn.zoo-project.org/trac/ticket/15#comment:4>
ZOO Project Trac <http://www.zoo-project.org/>
Open WPS Platform
More information about the Zoo-discuss mailing list
