[ZOO-Discuss] Error when running GRASS processes
    Soeren Gebbert
    soerengebbert at googlemail.com
    Fri Apr 29 00:00:13 PDT 2011
Hello,
...  <ows:Exception exceptionCode="InvalidParameterValue">
>>    <ows:ExceptionText>The value for <indetifier> seems to be
>> wrong (v.voronoi). Please, ensure that the process exist using the
>> GetCapabilities request.</ows:ExceptionText>
>>  </ows:Exception>
>> </ows:ExceptionReport>
> This is an unexpected error ... i don't know why this is not working
> with ZOO WPS??? I am using a POST request to deliver the XML content,
> maybe Gerald can clarify this issue?
Sorry, i have to correct me:
Everything is fine with ZOO but the service name in the XML execute
request and in the zcfg files are different. You need to change the
name v.voronoi into v_voronoi in the XML request file.
Best regards
Soeren
> Best regards
> Soeren
>> Cheers,
>> Pierre
>>> Best regards
>>> Soeren
>>>> Your help, and the efforts you are putting on open-source software,
>>>> is greatly appreciated.
>>>> Best,
>>>> Pierre
>>>>> Best regards
>>>>> Soeren
>>>>> 2011/4/28 Pierre Roudier <pierre.roudier at gmail.com>:
>>>>>> Dear zoo-keepers,
>>>>>> I'm trying the WPS GRASS bridge - unfortunately I can't make it work so far.
>>>>>> I've added two GRASS  processes to my /usr/lib/cgi-bin:
>>>>>> root at grass:/usr/local/src/zoo/zoo-kernel# ls /usr/lib/cgi-bin/ | grep .zcfg
>>>>>> HelloPy.zcfg
>>>>>> v_delaunay.zcfg
>>>>>> v_voronoi.zcfg
>>>>>> The GetCapabilities is working fine. In QGIS, I'm using the WPS plugin
>>>>>> to try to make a Voronoi tesselation or a Delaunay triangulation of a
>>>>>> dummy points shapefile. In both cases, I got the following error when
>>>>>> running the process:
>>>>>> <?xml version="1.0" encoding="utf-8"?>
>>>>>> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>> xmlns:xlink="http://www.w3.org/1999/xlink"
>>>>>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>>>>>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>>>>>> xml:lang="en-US" version="1.1.0">
>>>>>>  <ows:Exception exceptionCode="NoApplicableCode">
>>>>>>    <ows:ExceptionText>Python module v_delaunay cannot be loaded.
>>>>>>  </ows:Exception>
>>>>>> Any suggestion?
>>>>>> Cheers,
>>>>>> Pierre
>>>>>> Scientist
>>>>>> Landcare Research, New Zealand
>>>>>> _______________________________________________
>>>>>> Zoo-discuss mailing list
>>>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>>>> Scientist
>> Scientist
More information about the Zoo-discuss
