[ZOO-Discuss] Error when running GRASS processes
Luca Delucchi lucadeluge at gmail.com
Fri Apr 29 03:01:05 PDT 2011
2011/4/29 Soeren Gebbert <soerengebbert at googlemail.com>:
Hi Soeren
> Sorry my fault!
> The file GlobalGrassSettings.py must be present within this directory
> too. Additionally you must edit this file to set the paths to your
> GRASS GIS 7 installation and to the logfiles. The logfiles must be set
> writable for you webserver.
can you also change the page in the wiki [0], GlobalGrassSettings.py
is missing in the "Attaching the processes" in the files to copy in
zoo_loader.cgi folder
[0] http://code.google.com/p/wps-grass-bridge/wiki/ZOO_WPS_Integration#Attaching_the_processes
PS I restart to work on ZOO+WPS+GRASS but I have an error, some
suggestion? (I'm using qgis like client)
GDLA error while import. Unable to create input location from input
/var/www/zoograss/tmp/tmp_zXSaW/input_0 GDAL log: ERROR: Unable to
open data source </var/www/zoograss/tmp/tmp_zXSaW/input_0>
my directory is
ls -lh /var/www/zoograss/
total 4.0K
drwxrwxrwx 2 www-data www-data 4.0K Apr 29 11:57 tmp
cheers
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
