[ZOO-Discuss] Error when running GRASS processes
Soeren Gebbert
soerengebbert at googlemail.com
Fri Apr 29 03:38:48 PDT 2011
Hi Luca,
> can you also change the page in the wiki [0], GlobalGrassSettings.py
> is missing in the "Attaching the processes" in the files to copy in
> zoo_loader.cgi folder
> [0] http://code.google.com/p/wps-grass-bridge/wiki/ZOO_WPS_Integration#Attaching_the_processes
Many thanks for the hint, i have updated the wiki to make the
installation process clearer.
> PS I restart to work on ZOO+WPS+GRASS but I have an error, some
> suggestion? (I'm using qgis like client)
> GDLA error while import. Unable to create input location from input
> /var/www/zoograss/tmp/tmp_zXSaW/input_0 GDAL log: ERROR: Unable to
> open data source </var/www/zoograss/tmp/tmp_zXSaW/input_0>
> my directory is
> ls -lh /var/www/zoograss/
> total 4.0K
> drwxrwxrwx 2 www-data www-data 4.0K Apr 29 11:57 tmp
I suggest you are using the latest SVN of wps-grass-bridge and grass gis?
Is this error raster data related? What process are you running.
Please have a look at the file
/var/www/zoograss/tmp/tmp_zXSaW/input_0. What does gdalinfo says? In
case you are using base64 encoded data: is the data converted back
into binary format?
Best regards
Soeren
More information about the Zoo-discuss
