[ZOO-Discuss] Error when running GRASS processes
    Luca Delucchi
    lucadeluge at gmail.com
    Fri Apr 29 05:21:09 PDT 2011
2011/4/29 Soeren Gebbert <soerengebbert at googlemail.com>:
> I suggest you are using the latest SVN of wps-grass-bridge and grass gis?
yes, uploaded yesterday
> Is this error raster data related? What process are you running.
vector, I'm trying v.voronoy
> Please have a look at the file
> /var/www/zoograss/tmp/tmp_zXSaW/input_0. What does gdalinfo says? In
> case you are using base64 encoded data: is the data converted back
> into binary format?
there isn't tmp_zXSaW/ and tmp_zXSaW/input_0 maybe the problem is here...
I can try with a dataset already on my server to see if it work...
> Best regards
> Soeren
regards
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss
