[ZOO-Discuss] Boundary ZOO Service
Gérald Fenoy gerald.fenoy at geolabs.fr
Mon Feb 14 04:06:16 PST 2011
Dear Quang,
thanks for your investigations.
I suppose that on your line 265 you get the following :
 Vertex_circulator vc = ....
Please, try to use this :
 Vertex_circulator* vc = ....
Hope this help and you will give us feedback,
best
Le 14 févr. 2011 à 12:50, truongxuan quang a écrit :
> Dear Gérald
> Thank you for your help. I have checked again ../../zoo-kernel/service_internal.o, it missed service_internal.o file, I had copy from zoows.tar.bz2 I already avoid previous error "No such file or directory". But there is still error 265 in my command,  Could you please have a look for responsive inform bellow
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++ $CFLAGS -shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
> ./service.c: In function ‘void* createGeometryFromGML(maps*, char*)’:
> ./service.c:75: warning: deprecated conversion from string constant to ‘char*’
> ./service.c: In function ‘int Delaunay(maps*&, maps*&, maps*&)’:
> ./service.c:122: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:142: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:181: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:183: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:187: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:230: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:265: error: conversion from ‘CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Triangulation_euclidean_traits_xy_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >, CGAL::Triangulation_ds_vertex_base_2<void> >, CGAL::Triangulation_ds_face_base_2<void> > >’ to non-scalar type ‘Vertex_circulator’ requested
> ./service.c:379: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:384: warning: format ‘%d’ expects type ‘int’, but argument 4 has type ‘__off_t’
> ./service.c: In function ‘int Voronoi(maps*&, maps*&, maps*&)’:
> ./service.c:417: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:437: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:474: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:476: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:480: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:523: warning: deprecated conversion from string constant to ‘char*’
> ./service.c:595: warning: deprecated conversion from string constant to ‘char*’
>  in this directory  /usr/include/CGAL there is not including Triangulation_ds_vertex_circulator_2.h file as 265 error said.
> please help me to fix the error.
> Thank you very much and have a nice day
> T.X.Quang
> From: Gérald Fenoy <gerald.fenoy at geolabs.fr>
> To: truongxuan quang <truongxuanquang at yahoo.com>
> Cc: zoo-discuss <zoo-discuss at gisws.media.osaka-cu.ac.jp>
> Sent: Fri, February 11, 2011 7:34:55 PM
> Subject: Re: [ZOO-Discuss] Boundary ZOO Service
> Quang,
> I noticed something a bit strange in the error messages you shown to me.
> g++ is not able to find ../../zoo-kernel/service_internal.o from your ws_sp directory.
> Can you ensure that when you do "ls ../../zoo-kernel/service_internal.o" it gives you
> the file name rather than a message explaining that there is no file with that name.
> If you don't get the file, then you will probably have to compile zoo-kernel in the
> ../../zoo-kernel directory.
> Once you get the compiled ZOO-Kernel you should solve one issue. Then there
> is still the error about the line 265 of the service.c file. Let see if we can go to this
> last step.
> Hope it helps,
> Best
> Le 11 févr. 2011 à 18:33, truongxuan quang a écrit :
>> Dear Gérald
>> Thanks!  exactly I was missing CGAL so after install, it look better, I sent you the result what I have got.
>> g++: ../../zoo-kernel/service_internal.o: No such file or directory
>> Thank you and waiting for last help
>> Best,
>> T.X.Quang
>> Sent: Fri, February 11, 2011 5:36:32 PM
>> Dear Quang,
>> scuse me, at the beginning you used g++ so I didn't noticed that after you changed for
>> g++. It seems you need to use g++ in your case.
>> Your service provider is depending on CGAL. Are you sure you get it installed on your
>> OSGeoLiveDVD platform ?
>> If not, you probably would use the following command to install CGAL library and
>> header files (the -dev package in the Debian world):
>>   sudo apt-install search libcgal-dev
>> Maybe your service provider doesn't need GDAL library, in such case, please, remove
>> the include lines mentioning the CGAL directory.
>> Hope it help,
>> Best,
>> Le 11 févr. 2011 à 17:18, truongxuan quang a écrit :
>>> Thank you for help,  I am  sorry!!! but I need you help again because it still getting errors  after run the 3rd command
>>> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS -shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
>>> gcc: ../../zoo-kernel/service_internal.o: No such file or directory
>>> ./service.c:1:64: error: CGAL/Exact_predicates_inexact_constructions_kernel.h: No such file or directory
>>> ./service.c:2:54: error: CGAL/Triangulation_euclidean_traits_xy_3.h: No such file or directory
>>> ./service.c:3:43: error: CGAL/Delaunay_triangulation_2.h: No such file or directory
>>> ./service.c:4:55: error: CGAL/Constrained_Delaunay_triangulation_2.h: No such file or directory
>>> ./service.c:5:44: error: CGAL/Triangulation_conformer_2.h: No such file or directory
>>> ./service.c:6:44: error: CGAL/Triangulation_face_base_2.h: No such file or directory
>>> ./service.c:8:19: error: fstream: No such file or directory
>>> In file included from /usr/include/gdal/ogr_geometry.h:35,
>>>                  from /usr/include/gdal/ogr_feature.h:33,
>>>                  from /usr/include/gdal/ogrsf_frmts.h:33,
>>>                  from ./service.c:12:
>>> /usr/include/gdal/ogr_spatialref.h:59: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_spatialref.h:59: error: expected ‘,’ or ‘;’ before ‘OGR_SRSNode’
>>> /usr/include/gdal/ogr_spatialref.h:127: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_spatialref.h:127: error: expected ‘,’ or ‘;’ before ‘OGRSpatialReference’
>>> /usr/include/gdal/ogr_spatialref.h:515: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_spatialref.h:515: error: expected ‘,’ or ‘;’ before ‘OGRCoordinateTransformation’
>>> /usr/include/gdal/ogr_spatialref.h:571: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_spatialref.h:571: error: expected ‘,’ or ‘;’ before ‘*’ token
>>> In file included from /usr/include/gdal/ogr_feature.h:33,
>>> /usr/include/gdal/ogr_geometry.h:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRRawPoint’
>>> /usr/include/gdal/ogr_geometry.h:80: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:80: error: expected ‘,’ or ‘;’ before ‘OGRGeometry’
>>> /usr/include/gdal/ogr_geometry.h:169: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:169: error: expected ‘,’ or ‘;’ before ‘OGRPoint’
>>> /usr/include/gdal/ogr_geometry.h:224: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:224: error: expected ‘,’ or ‘;’ before ‘OGRCurve’
>>> /usr/include/gdal/ogr_geometry.h:246: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:246: error: expected ‘,’ or ‘;’ before ‘OGRLineString’
>>> /usr/include/gdal/ogr_geometry.h:338: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:338: error: expected ‘,’ or ‘;’ before ‘OGRLinearRing’
>>> /usr/include/gdal/ogr_geometry.h:381: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:381: error: expected ‘,’ or ‘;’ before ‘OGRSurface’
>>> /usr/include/gdal/ogr_geometry.h:402: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:402: error: expected ‘,’ or ‘;’ before ‘OGRPolygon’
>>> /usr/include/gdal/ogr_geometry.h:468: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:468: error: expected ‘,’ or ‘;’ before ‘OGRGeometryCollection’
>>> /usr/include/gdal/ogr_geometry.h:528: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:528: error: expected ‘,’ or ‘;’ before ‘OGRMultiPolygon’
>>> /usr/include/gdal/ogr_geometry.h:553: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:553: error: expected ‘,’ or ‘;’ before ‘OGRMultiPoint’
>>> /usr/include/gdal/ogr_geometry.h:579: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:579: error: expected ‘,’ or ‘;’ before ‘OGRMultiLineString’
>>> /usr/include/gdal/ogr_geometry.h:604: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_geometry.h:604: error: expected ‘,’ or ‘;’ before ‘OGRGeometryFactory’
>>> In file included from /usr/include/gdal/ogr_feature.h:34,
>>> /usr/include/gdal/ogr_featurestyle.h:37: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRFeature’
>>> /usr/include/gdal/ogr_featurestyle.h:81: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:81: error: expected ‘,’ or ‘;’ before ‘OGRStyleTable’
>>> /usr/include/gdal/ogr_featurestyle.h:110: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRStyleTool’
>>> /usr/include/gdal/ogr_featurestyle.h:115: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:115: error: expected ‘,’ or ‘;’ before ‘OGRStyleMgr’
>>> /usr/include/gdal/ogr_featurestyle.h:159: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:159: error: expected ‘,’ or ‘;’ before ‘OGRStyleTool’
>>> /usr/include/gdal/ogr_featurestyle.h:242: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:242: error: expected ‘,’ or ‘;’ before ‘OGRStylePen’
>>> /usr/include/gdal/ogr_featurestyle.h:290: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:290: error: expected ‘,’ or ‘;’ before ‘OGRStyleBrush’
>>> /usr/include/gdal/ogr_featurestyle.h:337: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:337: error: expected ‘,’ or ‘;’ before ‘OGRStyleSymbol’
>>> /usr/include/gdal/ogr_featurestyle.h:395: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_featurestyle.h:395: error: expected ‘,’ or ‘;’ before ‘OGRStyleLabel’
>>> In file included from /usr/include/gdal/ogrsf_frmts.h:33,
>>> /usr/include/gdal/ogr_feature.h:51: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_feature.h:51: error: expected ‘,’ or ‘;’ before ‘OGRFieldDefn’
>>> /usr/include/gdal/ogr_feature.h:113: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_feature.h:113: error: expected ‘,’ or ‘;’ before ‘OGRFeatureDefn’
>>> /usr/include/gdal/ogr_feature.h:159: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_feature.h:159: error: expected ‘,’ or ‘;’ before ‘OGRFeature’
>>> /usr/include/gdal/ogr_feature.h:296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRLayer’
>>> /usr/include/gdal/ogr_feature.h:298: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogr_feature.h:298: error: expected ‘,’ or ‘;’ before ‘OGRFeatureQuery’
>>> In file included from ./service.c:12:
>>> /usr/include/gdal/ogrsf_frmts.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRLayerAttrIndex’
>>> /usr/include/gdal/ogrsf_frmts.h:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRSFDriver’
>>> /usr/include/gdal/ogrsf_frmts.h:54: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogrsf_frmts.h:54: error: expected ‘,’ or ‘;’ before ‘OGRLayer’
>>> /usr/include/gdal/ogrsf_frmts.h:152: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogrsf_frmts.h:152: error: expected ‘,’ or ‘;’ before ‘OGRDataSource’
>>> /usr/include/gdal/ogrsf_frmts.h:231: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogrsf_frmts.h:231: error: expected ‘,’ or ‘;’ before ‘OGRSFDriver’
>>> /usr/include/gdal/ogrsf_frmts.h:264: warning: data definition has no type or storage class
>>> /usr/include/gdal/ogrsf_frmts.h:264: error: expected ‘,’ or ‘;’ before ‘OGRSFDriverRegistrar’
>>> ./service.c:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:19: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:21: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:25: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
>>> ./service.c:33: error: expected identifier or ‘(’ before string constant
>>> Thanks
>>> T.X.Quang
>>> Never miss an email again!
>>> Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
>> Gérald Fenoy
>> ZOO-PSC Chair
> Gérald Fenoy
> ZOO-PSC Chair
Gérald Fenoy
ZOO-PSC Chair
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110214/eeeda05e/attachment.html>
More information about the Zoo-discuss mailing list
