[ZOO-Discuss] Boundary ZOO Service
truongxuan quang
truongxuanquang at yahoo.com
Mon Feb 14 06:32:26 PST 2011
Dear Gérald
Thank you very much as you said, I have changed
/home/user/zoows/sources/zoo-services/ws_sp/service.c file line 265 from
Vertex_circulator vc = .... to Vertex_circulator* vc = .... and the feedback
comment as you can see below. Gérald, I just remember when I created ws_sp main
Services Provider directory in the existing zoo-services by
mkdir -p /home/user/zoows/sources/zoo-services/ws_sp/cgi-env
There was not include service.c inside ws_sp I had copied service.c from
http://zoo-project.org/trac/browser/branches/branch-1.2/zoo-services/cgal/service.c
it is right in this case ?
root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++ $CFLAGS
-shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
./service.c: In function ‘void* createGeometryFromGML(maps*, char*)’:
./service.c:75: warning: deprecated conversion from string constant to ‘char*’
./service.c: In function ‘int Delaunay(maps*&, maps*&, maps*&)’:
./service.c:122: warning: deprecated conversion from string constant to ‘char*’
./service.c:142: warning: deprecated conversion from string constant to ‘char*’
./service.c:181: warning: deprecated conversion from string constant to ‘char*’
./service.c:183: warning: deprecated conversion from string constant to ‘char*’
./service.c:187: warning: deprecated conversion from string constant to ‘char*’
./service.c:230: warning: deprecated conversion from string constant to ‘char*’
./service.c:265: error: cannot convert
‘CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Triangulation_euclidean_traits_xy_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, CGAL::Triangulation_ds_vertex_base_2<void> >,
CGAL::Triangulation_ds_face_base_2<void> > >’ to ‘Vertex_circulator*’ in
initialization
./service.c:268: error: ‘class
CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Triangulation_ds_face_base_2<void> > >’ has no member named ‘point’
./service.c:379: warning: deprecated conversion from string constant to ‘char*’
./service.c:384: warning: format ‘%d’ expects type ‘int’, but argument 4 has
type ‘__off_t’
./service.c: In function ‘int Voronoi(maps*&, maps*&, maps*&)’:
./service.c:417: warning: deprecated conversion from string constant to ‘char*’
./service.c:437: warning: deprecated conversion from string constant to ‘char*’
./service.c:474: warning: deprecated conversion from string constant to ‘char*’
./service.c:476: warning: deprecated conversion from string constant to ‘char*’
./service.c:480: warning: deprecated conversion from string constant to ‘char*’
./service.c:523: warning: deprecated conversion from string constant to ‘char*’
./service.c:595: warning: deprecated conversion from string constant to ‘char*’
Thanks
Quang
To: truongxuan quang <truongxuanquang at yahoo.com>
Cc: zoo-discuss <zoo-discuss at gisws.media.osaka-cu.ac.jp>
Sent: Mon, February 14, 2011 1:06:16 PM
Subject: Re: [ZOO-Discuss] Boundary ZOO Service
Dear Quang,
thanks for your investigations.
I suppose that on your line 265 you get the following :
Please, try to use this :
Hope this help and you will give us feedback,
best
Le 14 févr. 2011 à 12:50, truongxuan quang a écrit :
Dear Gérald
>Thank you for your help. I have checked again
>../../zoo-kernel/service_internal.o, it missed service_internal.o file, I had
>copy from zoows.tar.bz2 I already avoid previous error "No such file or
>directory". But there is still error 265 in my command, Could you please have a
>look for responsive inform bellow
>./service.c:265: error: conversion from
>CGAL::Triangulation_ds_face_base_2<void> > >’ to non-scalar type
>‘Vertex_circulator’ requested
>type ‘__off_t’
> in this directory /usr/include/CGAL there is not including
>Triangulation_ds_vertex_circulator_2.h file as 265 error said.
>please help me to fix the error.
>Thank you very much and have a nice day
>T.X.Quang
>Sent: Fri, February 11, 2011 7:34:55 PM
>Quang,
>I noticed something a bit strange in the error messages you shown to me.
>g++ is not able to find ../../zoo-kernel/service_internal.o from your ws_sp
>directory.
>Can you ensure that when you do "ls ../../zoo-kernel/service_internal.o" it
>gives you
>the file name rather than a message explaining that there is no file with that
>name.
>If you don't get the file, then you will probably have to compile zoo-kernel in
>the
>../../zoo-kernel directory.
>Once you get the compiled ZOO-Kernel you should solve one issue. Then there
>is still the error about the line 265 of the service.c file. Let see if we can
>go to this
>last step.
>Hope it helps,
>Best
>Le 11 févr. 2011 à 18:33, truongxuan quang a écrit :
>Dear Gérald
>>Thanks! exactly I was missing CGAL so after install, it look better, I sent you
>>the result what I have got.
>>g++: ../../zoo-kernel/service_internal.o: No such file or directory
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
>>type ‘__off_t’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
>>Thank you and waiting for last help
>>Best,
>>T.X.Quang
>>Sent: Fri, February 11, 2011 5:36:32 PM
>>Dear Quang,
>>scuse me, at the beginning you used g++ so I didn't noticed that after you
>>changed for
>>g++. It seems you need to use g++ in your case.
>>Your service provider is depending on CGAL. Are you sure you get it installed on
>>your
>>OSGeoLiveDVD platform ?
>>If not, you probably would use the following command to install CGAL library
>>and
>>header files (the -dev package in the Debian world):
>> sudo apt-install search libcgal-dev
>>Maybe your service provider doesn't need GDAL library, in such case, please,
>>remove
>>the include lines mentioning the CGAL directory.
>>Hope it help,
>>Best,
>>Le 11 févr. 2011 à 17:18, truongxuan quang a écrit :
>>>Thank you for help, I am sorry!!! but I need you help again because it still
>>>getting errors after run the 3rd command
>>>root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS
>>>gcc: ../../zoo-kernel/service_internal.o: No such file or directory
>>>./service.c:1:64: error: CGAL/Exact_predicates_inexact_constructions_kernel.h:
>>>./service.c:2:54: error: CGAL/Triangulation_euclidean_traits_xy_3.h: No such
>>>file or directory
>>>./service.c:3:43: error: CGAL/Delaunay_triangulation_2.h: No such file or
>>>directory
>>>./service.c:4:55: error: CGAL/Constrained_Delaunay_triangulation_2.h: No such
>>>file or directory
>>>./service.c:5:44: error: CGAL/Triangulation_conformer_2.h: No such file or
>>>directory
>>>./service.c:6:44: error: CGAL/Triangulation_face_base_2.h: No such file or
>>>directory
>>>./service.c:8:19: error: fstream: No such file or directory
>>>In file included from /usr/include/gdal/ogr_geometry.h:35,
>>> from /usr/include/gdal/ogr_feature.h:33,
>>> from /usr/include/gdal/ogrsf_frmts.h:33,
>>> from ./service.c:12:
>>>/usr/include/gdal/ogr_spatialref.h:59: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_spatialref.h:59: error: expected ‘,’ or ‘;’ before
>>>‘OGR_SRSNode’
>>>/usr/include/gdal/ogr_spatialref.h:127: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_spatialref.h:127: error: expected ‘,’ or ‘;’ before
>>>‘OGRSpatialReference’
>>>/usr/include/gdal/ogr_spatialref.h:515: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_spatialref.h:515: error: expected ‘,’ or ‘;’ before
>>>‘OGRCoordinateTransformation’
>>>/usr/include/gdal/ogr_spatialref.h:571: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_spatialref.h:571: error: expected ‘,’ or ‘;’ before ‘*’
>>>token
>>>In file included from /usr/include/gdal/ogr_feature.h:33,
>>>/usr/include/gdal/ogr_geometry.h:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>‘__attribute__’ before ‘OGRRawPoint’
>>>/usr/include/gdal/ogr_geometry.h:80: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:80: error: expected ‘,’ or ‘;’ before
>>>‘OGRGeometry’
>>>/usr/include/gdal/ogr_geometry.h:169: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:169: error: expected ‘,’ or ‘;’ before
>>>‘OGRPoint’
>>>/usr/include/gdal/ogr_geometry.h:224: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:224: error: expected ‘,’ or ‘;’ before
>>>‘OGRCurve’
>>>/usr/include/gdal/ogr_geometry.h:246: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:246: error: expected ‘,’ or ‘;’ before
>>>‘OGRLineString’
>>>/usr/include/gdal/ogr_geometry.h:338: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:338: error: expected ‘,’ or ‘;’ before
>>>‘OGRLinearRing’
>>>/usr/include/gdal/ogr_geometry.h:381: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:381: error: expected ‘,’ or ‘;’ before
>>>‘OGRSurface’
>>>/usr/include/gdal/ogr_geometry.h:402: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:402: error: expected ‘,’ or ‘;’ before
>>>‘OGRPolygon’
>>>/usr/include/gdal/ogr_geometry.h:468: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:468: error: expected ‘,’ or ‘;’ before
>>>‘OGRGeometryCollection’
>>>/usr/include/gdal/ogr_geometry.h:528: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:528: error: expected ‘,’ or ‘;’ before
>>>‘OGRMultiPolygon’
>>>/usr/include/gdal/ogr_geometry.h:553: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:553: error: expected ‘,’ or ‘;’ before
>>>‘OGRMultiPoint’
>>>/usr/include/gdal/ogr_geometry.h:579: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:579: error: expected ‘,’ or ‘;’ before
>>>‘OGRMultiLineString’
>>>/usr/include/gdal/ogr_geometry.h:604: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_geometry.h:604: error: expected ‘,’ or ‘;’ before
>>>‘OGRGeometryFactory’
>>>In file included from /usr/include/gdal/ogr_feature.h:34,
>>>/usr/include/gdal/ogr_featurestyle.h:37: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>‘__attribute__’ before ‘OGRFeature’
>>>/usr/include/gdal/ogr_featurestyle.h:81: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_featurestyle.h:81: error: expected ‘,’ or ‘;’ before
>>>‘OGRStyleTable’
>>>/usr/include/gdal/ogr_featurestyle.h:110: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>>or ‘__attribute__’ before ‘OGRStyleTool’
>>>/usr/include/gdal/ogr_featurestyle.h:115: warning: data definition has no type
>>>or storage class
>>>/usr/include/gdal/ogr_featurestyle.h:115: error: expected ‘,’ or ‘;’ before
>>>‘OGRStyleMgr’
>>>/usr/include/gdal/ogr_featurestyle.h:159: warning: data definition has no type
>>>or storage class
>>>/usr/include/gdal/ogr_featurestyle.h:159: error: expected ‘,’ or ‘;’ before
>>>‘OGRStyleTool’
>>>/usr/include/gdal/ogr_featurestyle.h:242: warning: data definition has no type
>>>or storage class
>>>/usr/include/gdal/ogr_featurestyle.h:242: error: expected ‘,’ or ‘;’ before
>>>‘OGRStylePen’
>>>/usr/include/gdal/ogr_featurestyle.h:290: warning: data definition has no type
>>>or storage class
>>>/usr/include/gdal/ogr_featurestyle.h:290: error: expected ‘,’ or ‘;’ before
>>>‘OGRStyleBrush’
>>>/usr/include/gdal/ogr_featurestyle.h:337: warning: data definition has no type
>>>or storage class
>>>/usr/include/gdal/ogr_featurestyle.h:337: error: expected ‘,’ or ‘;’ before
>>>‘OGRStyleSymbol’
>>>/usr/include/gdal/ogr_featurestyle.h:395: warning: data definition has no type
>>>or storage class
>>>/usr/include/gdal/ogr_featurestyle.h:395: error: expected ‘,’ or ‘;’ before
>>>‘OGRStyleLabel’
>>>In file included from /usr/include/gdal/ogrsf_frmts.h:33,
>>>/usr/include/gdal/ogr_feature.h:51: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_feature.h:51: error: expected ‘,’ or ‘;’ before
>>>‘OGRFieldDefn’
>>>/usr/include/gdal/ogr_feature.h:113: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_feature.h:113: error: expected ‘,’ or ‘;’ before
>>>‘OGRFeatureDefn’
>>>/usr/include/gdal/ogr_feature.h:159: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_feature.h:159: error: expected ‘,’ or ‘;’ before
>>>‘OGRFeature’
>>>/usr/include/gdal/ogr_feature.h:296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>‘__attribute__’ before ‘OGRLayer’
>>>/usr/include/gdal/ogr_feature.h:298: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogr_feature.h:298: error: expected ‘,’ or ‘;’ before
>>>‘OGRFeatureQuery’
>>>In file included from ./service.c:12:
>>>/usr/include/gdal/ogrsf_frmts.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>‘__attribute__’ before ‘OGRLayerAttrIndex’
>>>/usr/include/gdal/ogrsf_frmts.h:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>‘__attribute__’ before ‘OGRSFDriver’
>>>/usr/include/gdal/ogrsf_frmts.h:54: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogrsf_frmts.h:54: error: expected ‘,’ or ‘;’ before
>>‘OGRLayer’
>>>/usr/include/gdal/ogrsf_frmts.h:152: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogrsf_frmts.h:152: error: expected ‘,’ or ‘;’ before
>>>‘OGRDataSource’
>>>/usr/include/gdal/ogrsf_frmts.h:231: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogrsf_frmts.h:231: error: expected ‘,’ or ‘;’ before
>>>‘OGRSFDriver’
>>>/usr/include/gdal/ogrsf_frmts.h:264: warning: data definition has no type or
>>>storage class
>>>/usr/include/gdal/ogrsf_frmts.h:264: error: expected ‘,’ or ‘;’ before
>>>‘OGRSFDriverRegistrar’
>>>./service.c:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:19: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:21: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:25: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>‘:’ token
>>>./service.c:33: error: expected identifier or ‘(’ before string constant
>>>Thanks
>>>T.X.Quang
Never miss an email again!
>>>Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
>>Gérald Fenoy
>>ZOO-PSC Chair
>>gerald.fenoy at geolabs.fr
>Gérald Fenoy
>ZOO-PSC Chair
Gérald Fenoy
ZOO-PSC Chair
____________________________________________________________________________________
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110214/7c0f91b0/attachment.html>
More information about the Zoo-discuss
