[ZOO-Discuss] CGAL ZOO Service
nicolas bozon nicolas.bozon at gmail.com
Wed Feb 16 06:31:52 PST 2011
Hi Quang, All,
Just to let you know that the CGAL ZOO Service and corresponding .zcfg file
have been recently updated. You can chek it here:
http://zoo-project.org/trac/browser/trunk/zoo-services/cgal
A small Voronoï demo using a huge point layer is also working here:
http://zoo-project.org/site/ZooWebSite/Demo/CGAL
Best regards,
Nick
2011/2/15 Gérald Fenoy <gerald.fenoy at geolabs.fr>
> Dear Quang,
> in other case you can always comment the function which cause trouble
>  and you'll maybe find a way to get the Delaunay function working.
> I know that the Voronoi worked when we tested it, we used some data
> provided by 3liz and built a demo on top of this dataset [1]. It worked
> like a
> charm until 3liz remove the dataset they gave us access to. Maybe you
> can first start using the demo page and test the Voronoi Service which
> should work, then test using your own dataset.
> As we spoken together about this old Demo page I was able to port this
> old demo page on the trac, so it is now even accessible from the
> official ZOO-Project web site [2].
> So it you're interested in the CGAL library you should probably know it
> better than I do, it can be a real asset to get the Delaunay function
> working even if we already get those algorithms  available from
> GRASS7 WPS Bridge made available by Soeren Gebbert (which I
> thanks one more time for his welcomed help in such a task).
> Hope you can solve the issue about Delaunay service and hope this
> new demo page can help you in testing the Voronoï algorithm from the
> CGAL library.
> Best regards,
> [1] http://zoo-project.org/ogr/cgal-demo.html
> [2] http://zoo-project.org/site/ZooWebSite/Demo/CGAL
> Le 14 févr. 2011 à 17:20, truongxuan quang a écrit :
> Dear Gérald
> Thank for all you help...I will move to the ogr/base-vect-ops first and if
> I have time I will look back for CGAL, because CGAL's library attracted me.
> I will focus in next section if I face any doubts please help me again.
> Thank you very much
> Quang
> *From:* Gérald Fenoy <gerald.fenoy at geolabs.fr>
> *To:* truongxuan quang <truongxuanquang at yahoo.com>
> *Cc:* zoo-discuss <zoo-discuss at gisws.media.osaka-cu.ac.jp>
> *Sent:* Mon, February 14, 2011 4:43:55 PM
> *Subject:* Re: [ZOO-Discuss] Boundary ZOO Service
> Dear Quang,
> as I think you was trying the Workshop material, you shouldn't download any
> source code
> from the SVN tree ... You should create an empty file and fill it with the
> content provided in
> the workshop material.
> CGAL service seems to get trouble, we tried it some *years* ago with
> probably an older
> CGAL version ... not sure.
> Probably switching to the ogr/base-vect-ops, which is the service used in
> the workshop
> material would be easier.
> Hope to hear from you,
> Best,
> Le 14 févr. 2011 à 15:32, truongxuan quang a écrit :
> Dear Gérald
> Thank you very much as you said, I have changed
> /home/user/zoows/sources/zoo-services/ws_sp/service.c file line 265  from
> Vertex_circulator vc = .... to Vertex_circulator* vc = .... and the feedback
> comment as you can see below. Gérald, I just remember when I created ws_sp
> main Services Provider directory in the existing zoo-services by
> mkdir -p /home/user/zoows/sources/zoo-services/ws_sp/cgi-env
> There was not include service.c inside ws_sp I had copied service.c from
> http://zoo-project.org/trac/browser/branches/branch-1.2/zoo-services/cgal/service.c
>  it is right in this case ?
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++
> $CFLAGS -shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
> ./service.c: In function ‘void* createGeometryFromGML(maps*, char*)’:
> ./service.c:75: warning: deprecated conversion from string constant to
> ‘char*’
> ./service.c: In function ‘int Delaunay(maps*&, maps*&, maps*&)’:
> ./service.c:122: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:142: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:181: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:183: warning: deprecated conversion from string constant to
> ‘char*’
> ./service.c:187: warning: deprecated conversion from string constant to
> ‘char*’
> ./service.c:230: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:265: error: cannot convert
> ‘CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Triangulation_euclidean_traits_xy_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >, CGAL::Triangulation_ds_vertex_base_2<void> >,
> CGAL::Triangulation_ds_face_base_2<void> > >’ to ‘Vertex_circulator*’ in
> initialization
> ./service.c:268: error: ‘class
> CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> CGAL::Triangulation_ds_face_base_2<void> > >’ has no member named ‘point’
> ./service.c:379: warning: deprecated conversion from string constant to
> ‘char*’
> ./service.c:384: warning: format ‘%d’ expects type ‘int’, but argument 4
> has type ‘__off_t’
> ./service.c: In function ‘int Voronoi(maps*&, maps*&, maps*&)’:
> ./service.c:417: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:437: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:474: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:476: warning: deprecated conversion from string constant to
> ‘char*’
> ./service.c:480: warning: deprecated conversion from string constant to
> ‘char*’
> ./service.c:523: warning: deprecated conversion from string constant to
> ‘char*’
> ‘char*’
> ./service.c:595: warning: deprecated conversion from string constant to
> ‘char*’
> Thanks
> Quang
> *Sent:* Mon, February 14, 2011 1:06:16 PM
> Dear Quang,
> thanks for your investigations.
> I suppose that on your line 265 you get the following :
> Please, try to use this :
> Hope this help and you will give us feedback,
> best
> Le 14 févr. 2011 à 12:50, truongxuan quang a écrit :
> Dear Gérald
> Thank you for your help. I have checked again
> ../../zoo-kernel/service_internal.o, it missed service_internal.o file, I
> had copy from zoows.tar.bz2 I already avoid previous error "No such file
> or directory". But there is still error 265 in my command,  Could you
> please have a look for responsive inform bellow
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ./service.c:265: error: conversion from
> CGAL::Triangulation_ds_face_base_2<void> > >’ to non-scalar type
> ‘Vertex_circulator’ requested
> ‘char*’
> has type ‘__off_t’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
>  in this directory  /usr/include/CGAL there is not including
> Triangulation_ds_vertex_circulator_2.h file as 265 error said.
> please help me to fix the error.
> Thank you very much and have a nice day
> T.X.Quang
> *Sent:* Fri, February 11, 2011 7:34:55 PM
> Quang,
> I noticed something a bit strange in the error messages you shown to me.
> g++ is not able to find ../../zoo-kernel/service_internal.o from your ws_sp
> directory.
> Can you ensure that when you do "ls ../../zoo-kernel/service_internal.o" it
> gives you
> the file name rather than a message explaining that there is no file with
> that name.
> If you don't get the file, then you will probably have to compile
> zoo-kernel in the
> ../../zoo-kernel directory.
> Once you get the compiled ZOO-Kernel you should solve one issue. Then
> there
> is still the error about the line 265 of the service.c file. Let see if we
> can go to this
> last step.
> Hope it helps,
> Best
> Le 11 févr. 2011 à 18:33, truongxuan quang a écrit :
> Dear Gérald
> Thanks!  exactly I was missing CGAL so after install, it look better, I
> sent you the result what I have got.
> g++: ../../zoo-kernel/service_internal.o: No such file or directory
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> has type ‘__off_t’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> ‘char*’
> Thank you and waiting for last help
> Best,
> T.X.Quang
> *Sent:* Fri, February 11, 2011 5:36:32 PM
> Dear Quang,
> scuse me, at the beginning you used g++ so I didn't noticed that after you
> changed for
> g++. It seems you need to use g++ in your case.
> Your service provider is depending on CGAL. Are you sure you get it
> installed on your
> OSGeoLiveDVD platform ?
> If not, you probably would use the following command to install CGAL
> library and
> header files (the -dev package in the Debian world):
>   sudo apt-install search libcgal-dev
> Maybe your service provider doesn't need GDAL library, in such case,
> please, remove
> the include lines mentioning the CGAL directory.
> Hope it help,
> Best,
> Le 11 févr. 2011 à 17:18, truongxuan quang a écrit :
> Thank you for help,  I am  sorry!!! but I need you help again because it
> still getting errors  after run the 3rd command
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc
> gcc: ../../zoo-kernel/service_internal.o: No such file or directory
> ./service.c:1:64: error:
> CGAL/Exact_predicates_inexact_constructions_kernel.h: No such file or
> directory
> ./service.c:2:54: error: CGAL/Triangulation_euclidean_traits_xy_3.h: No
> ./service.c:3:43: error: CGAL/Delaunay_triangulation_2.h: No such file or
> directory
> ./service.c:4:55: error: CGAL/Constrained_Delaunay_triangulation_2.h: No
> ./service.c:5:44: error: CGAL/Triangulation_conformer_2.h: No such file or
> directory
> ./service.c:6:44: error: CGAL/Triangulation_face_base_2.h: No such file or
> directory
> ./service.c:8:19: error: fstream: No such file or directory
> In file included from /usr/include/gdal/ogr_geometry.h:35,
>                  from /usr/include/gdal/ogr_feature.h:33,
>                  from /usr/include/gdal/ogrsf_frmts.h:33,
>                  from ./service.c:12:
> /usr/include/gdal/ogr_spatialref.h:59: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_spatialref.h:59: error: expected ‘,’ or ‘;’ before
> ‘OGR_SRSNode’
> /usr/include/gdal/ogr_spatialref.h:127: warning: data definition has no
> type or storage class
> /usr/include/gdal/ogr_spatialref.h:127: error: expected ‘,’ or ‘;’ before
> ‘OGRSpatialReference’
> /usr/include/gdal/ogr_spatialref.h:515: warning: data definition has no
> /usr/include/gdal/ogr_spatialref.h:515: error: expected ‘,’ or ‘;’ before
> ‘OGRCoordinateTransformation’
> /usr/include/gdal/ogr_spatialref.h:571: warning: data definition has no
> /usr/include/gdal/ogr_spatialref.h:571: error: expected ‘,’ or ‘;’ before
> ‘*’ token
> In file included from /usr/include/gdal/ogr_feature.h:33,
> /usr/include/gdal/ogr_geometry.h:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
> or ‘__attribute__’ before ‘OGRRawPoint’
> /usr/include/gdal/ogr_geometry.h:80: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:80: error: expected ‘,’ or ‘;’ before
> ‘OGRGeometry’
> /usr/include/gdal/ogr_geometry.h:169: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:169: error: expected ‘,’ or ‘;’ before
> ‘OGRPoint’
> /usr/include/gdal/ogr_geometry.h:224: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:224: error: expected ‘,’ or ‘;’ before
> ‘OGRCurve’
> /usr/include/gdal/ogr_geometry.h:246: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:246: error: expected ‘,’ or ‘;’ before
> ‘OGRLineString’
> /usr/include/gdal/ogr_geometry.h:338: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:338: error: expected ‘,’ or ‘;’ before
> ‘OGRLinearRing’
> /usr/include/gdal/ogr_geometry.h:381: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:381: error: expected ‘,’ or ‘;’ before
> ‘OGRSurface’
> /usr/include/gdal/ogr_geometry.h:402: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:402: error: expected ‘,’ or ‘;’ before
> ‘OGRPolygon’
> /usr/include/gdal/ogr_geometry.h:468: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:468: error: expected ‘,’ or ‘;’ before
> ‘OGRGeometryCollection’
> /usr/include/gdal/ogr_geometry.h:528: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:528: error: expected ‘,’ or ‘;’ before
> ‘OGRMultiPolygon’
> /usr/include/gdal/ogr_geometry.h:553: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:553: error: expected ‘,’ or ‘;’ before
> ‘OGRMultiPoint’
> /usr/include/gdal/ogr_geometry.h:579: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:579: error: expected ‘,’ or ‘;’ before
> ‘OGRMultiLineString’
> /usr/include/gdal/ogr_geometry.h:604: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_geometry.h:604: error: expected ‘,’ or ‘;’ before
> ‘OGRGeometryFactory’
> In file included from /usr/include/gdal/ogr_feature.h:34,
> /usr/include/gdal/ogr_featurestyle.h:37: error: expected ‘=’, ‘,’, ‘;’,
> ‘asm’ or ‘__attribute__’ before ‘OGRFeature’
> /usr/include/gdal/ogr_featurestyle.h:81: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:81: error: expected ‘,’ or ‘;’ before
> ‘OGRStyleTable’
> /usr/include/gdal/ogr_featurestyle.h:110: error: expected ‘=’, ‘,’, ‘;’,
> ‘asm’ or ‘__attribute__’ before ‘OGRStyleTool’
> /usr/include/gdal/ogr_featurestyle.h:115: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:115: error: expected ‘,’ or ‘;’ before
> ‘OGRStyleMgr’
> /usr/include/gdal/ogr_featurestyle.h:159: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:159: error: expected ‘,’ or ‘;’ before
> ‘OGRStyleTool’
> /usr/include/gdal/ogr_featurestyle.h:242: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:242: error: expected ‘,’ or ‘;’ before
> ‘OGRStylePen’
> /usr/include/gdal/ogr_featurestyle.h:290: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:290: error: expected ‘,’ or ‘;’ before
> ‘OGRStyleBrush’
> /usr/include/gdal/ogr_featurestyle.h:337: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:337: error: expected ‘,’ or ‘;’ before
> ‘OGRStyleSymbol’
> /usr/include/gdal/ogr_featurestyle.h:395: warning: data definition has no
> /usr/include/gdal/ogr_featurestyle.h:395: error: expected ‘,’ or ‘;’ before
> ‘OGRStyleLabel’
> In file included from /usr/include/gdal/ogrsf_frmts.h:33,
> /usr/include/gdal/ogr_feature.h:51: warning: data definition has no type or
> storage class
> /usr/include/gdal/ogr_feature.h:51: error: expected ‘,’ or ‘;’ before
> ‘OGRFieldDefn’
> /usr/include/gdal/ogr_feature.h:113: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_feature.h:113: error: expected ‘,’ or ‘;’ before
> ‘OGRFeatureDefn’
> /usr/include/gdal/ogr_feature.h:159: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_feature.h:159: error: expected ‘,’ or ‘;’ before
> ‘OGRFeature’
> /usr/include/gdal/ogr_feature.h:296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
> or ‘__attribute__’ before ‘OGRLayer’
> /usr/include/gdal/ogr_feature.h:298: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogr_feature.h:298: error: expected ‘,’ or ‘;’ before
> ‘OGRFeatureQuery’
> In file included from ./service.c:12:
> /usr/include/gdal/ogrsf_frmts.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘OGRLayerAttrIndex’
> /usr/include/gdal/ogrsf_frmts.h:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘OGRSFDriver’
> /usr/include/gdal/ogrsf_frmts.h:54: warning: data definition has no type or
> storage class
> /usr/include/gdal/ogrsf_frmts.h:54: error: expected ‘,’ or ‘;’ before
> ‘OGRLayer’
> /usr/include/gdal/ogrsf_frmts.h:152: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogrsf_frmts.h:152: error: expected ‘,’ or ‘;’ before
> ‘OGRDataSource’
> /usr/include/gdal/ogrsf_frmts.h:231: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogrsf_frmts.h:231: error: expected ‘,’ or ‘;’ before
> ‘OGRSFDriver’
> /usr/include/gdal/ogrsf_frmts.h:264: warning: data definition has no type
> or storage class
> /usr/include/gdal/ogrsf_frmts.h:264: error: expected ‘,’ or ‘;’ before
> ‘OGRSFDriverRegistrar’
> ./service.c:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:19: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:21: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:25: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’
> before ‘:’ token
> ./service.c:33: error: expected identifier or ‘(’ before string constant
> Thanks
> T.X.Quang
> Gérald Fenoy
> ZOO-PSC Chair
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110216/25fe0841/attachment.html>
More information about the Zoo-discuss mailing list
