[ZOO-Discuss] libphp error when compiling the kernel - svn version
nicolas bozon nicolas.bozon at gmail.com
Mon Feb 21 04:01:27 PST 2011
Hi Pierre,
Thanks for your interest in ZOO Kernel and its PHP capabilities.
Some useful information is gathered here about PHP (if not read yet) here:
http://zoo-project.org/trac/wiki/ZooKernel/Embed/PHP
Please note that you need the PHP Embed version and that  *--enable-embed*and
*'--enable-maintainer-zts* are mandatory options.
Hope it helps,
Best
Nick
2011/2/21 Pierre Roudier <pierre.roudier at gmail.com>
> Hi Angelo,
> Thanks for the pointer, that's most helpful, and I will go for the
> repo solution for my OpenSuse workstation.
> However, as I'm very curious, if anybody has specifications to the
> libphp to include, I'm all hears :)
> Pierre
> 2011/2/21 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> > Hi Pierre,
> > There is an openSUSE repository for zoo kernel.
> > http://download.opensuse.org/repositories/home:/tzotsos/openSUSE_11.3/
> > You also have to add Application:Geo repository:
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.3/
> > Right now it does not support js or PHP but in the future this will
> change.
> > For setting up grass wps bridge I don't recall needing those 2.
> > Regards,
> > Angelos
> > On 02/21/2011 12:03 AM, Pierre Roudier wrote:
> >> Hi all,
> >> I'm trying to compile the ZOO kernel from svn (in the hope to test the
> >> grass wps bridge), but I'm stuck with the very same config error for a
> >> while now.
> >> These are my ./configure options:
> >> ./configure --with-js=/usr/
> >> --with-gdal-config=/usr/bin/gdal-config
> >> --with-php=/usr/lib/php5.2.10/
> >> --with-java=/usr/lib64/jvm/java --with-php=/usr/bin/php-config
> >> And this is the output of the command - for readibility just the
> >> interesting bits:
> >> ./configure: line 5588: /usr/bin/php-config/bin/php-config: Not a
> directory
> >> ./configure: line 5589: /usr/bin/php-config/bin/php-config: Not a
> directory
> >> checking sapi/embed/php_embed.h usability... no
> >> checking sapi/embed/php_embed.h presence... no
> >> checking for sapi/embed/php_embed.h... no
> >> configure: error: could not find headers include related to libphp
> >> locate php-config gives me the following output:
> >> /etc/alternatives/php-config
> >> /etc/alternatives/php-config.1
> >> /usr/bin/php-config
> >> /usr/bin/php-config5
> >> /usr/share/man/man1/php-config5.1.gz
> >> /var/lib/rpm/alternatives/php-config
> >> My configuration is a 64bits, Opensuse 11.3. Any help would be much
> appreciated.
> >> Pierre
> > Angelos Tzotsos
> > Remote Sensing Laboratory
> > National Technical University of Athens
> > http://users.ntua.gr/tzotsos
> > Zoo-discuss mailing list
> > Zoo-discuss at gisws.media.osaka-cu.ac.jp
> > http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Scientist
> Landcare Research, New Zealand
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110221/72e1ba8b/attachment.html>
More information about the Zoo-discuss mailing list
