[ZOO-Discuss] libphp error when compiling the kernel - svn version
Pierre Roudier
pierre.roudier at gmail.com
Sun Feb 20 20:31:48 PST 2011
Hi Angelo,
Thanks for the pointer, that's most helpful, and I will go for the
repo solution for my OpenSuse workstation.
However, as I'm very curious, if anybody has specifications to the
libphp to include, I'm all hears :)
Pierre
2011/2/21 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Hi Pierre,
> There is an openSUSE repository for zoo kernel.
> http://download.opensuse.org/repositories/home:/tzotsos/openSUSE_11.3/
> You also have to add Application:Geo repository:
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.3/
> Right now it does not support js or PHP but in the future this will change.
> For setting up grass wps bridge I don't recall needing those 2.
> Regards,
> Angelos
> On 02/21/2011 12:03 AM, Pierre Roudier wrote:
>> Hi all,
>> I'm trying to compile the ZOO kernel from svn (in the hope to test the
>> grass wps bridge), but I'm stuck with the very same config error for a
>> while now.
>> These are my ./configure options:
>> ./configure --with-js=/usr/
>> --with-gdal-config=/usr/bin/gdal-config
>> --with-php=/usr/lib/php5.2.10/
>> --with-java=/usr/lib64/jvm/java --with-php=/usr/bin/php-config
>> And this is the output of the command - for readibility just the
>> interesting bits:
>> ./configure: line 5588: /usr/bin/php-config/bin/php-config: Not a directory
>> ./configure: line 5589: /usr/bin/php-config/bin/php-config: Not a directory
>> checking sapi/embed/php_embed.h usability... no
>> checking sapi/embed/php_embed.h presence... no
>> checking for sapi/embed/php_embed.h... no
>> configure: error: could not find headers include related to libphp
>> locate php-config gives me the following output:
>> /etc/alternatives/php-config
>> /etc/alternatives/php-config.1
>> /usr/bin/php-config
>> /usr/bin/php-config5
>> /usr/share/man/man1/php-config5.1.gz
>> /var/lib/rpm/alternatives/php-config
>> My configuration is a 64bits, Opensuse 11.3. Any help would be much appreciated.
>> Pierre
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Scientist
Landcare Research, New Zealand
More information about the Zoo-discuss
