[ZOO-Discuss] libphp error when compiling the kernel - svn version
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sun Feb 20 16:21:48 PST 2011
Hi Pierre,
There is an openSUSE repository for zoo kernel.
http://download.opensuse.org/repositories/home:/tzotsos/openSUSE_11.3/
You also have to add Application:Geo repository:
http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.3/
Right now it does not support js or PHP but in the future this will change.
For setting up grass wps bridge I don't recall needing those 2.
Regards,
Angelos
On 02/21/2011 12:03 AM, Pierre Roudier wrote:
> Hi all,
> I'm trying to compile the ZOO kernel from svn (in the hope to test the
> grass wps bridge), but I'm stuck with the very same config error for a
> while now.
> These are my ./configure options:
> ./configure --with-js=/usr/
> --with-gdal-config=/usr/bin/gdal-config
> --with-php=/usr/lib/php5.2.10/
> --with-java=/usr/lib64/jvm/java --with-php=/usr/bin/php-config
> And this is the output of the command - for readibility just the
> interesting bits:
> ./configure: line 5588: /usr/bin/php-config/bin/php-config: Not a directory
> ./configure: line 5589: /usr/bin/php-config/bin/php-config: Not a directory
> checking sapi/embed/php_embed.h usability... no
> checking sapi/embed/php_embed.h presence... no
> checking for sapi/embed/php_embed.h... no
> configure: error: could not find headers include related to libphp
> locate php-config gives me the following output:
> /etc/alternatives/php-config
> /etc/alternatives/php-config.1
> /usr/bin/php-config
> /usr/bin/php-config5
> /usr/share/man/man1/php-config5.1.gz
> /var/lib/rpm/alternatives/php-config
> My configuration is a 64bits, Opensuse 11.3. Any help would be much appreciated.
> Pierre
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Zoo-discuss
