[ZOO-Discuss] [ZOO Project Trac] #16: JavaScript package on Ubuntu
ZOO Project Trac
zoo-dev at cartography.st
Thu Jan 27 05:55:50 PST 2011
Reporter: reluc | Owner:
Type: defect | Status: reopened
Priority: major | Milestone:
Component: zoo-kernel | Version: 1.0
Resolution: | Keywords: JS config compilation
Changes (by djay):
* status: closed => reopened
* resolution: fixed =>
Comment:
David explained to me that finally I was wrong using the grep dev on
xulrunner as there is 2 different packages (including one meta package).
Moreover, when you try to compile the JavaScript support on debian like
distribution, you should then specify only --with-js without any path set
to activate autodetection. If you set any path here, then libmozjs will be
located as header files required.
The historical libjs will be removed and libmozjs will used from now.
David is making modifications right now and should commit his
modifications soon.
Ticket URL: <http://svn.zoo-project.org/trac/ticket/16#comment:4>
ZOO Project Trac <http://www.zoo-project.org/>
Open WPS Platform
More information about the Zoo-discuss
