[ZOO-Discuss] Execute request returns SIGSEGV message from the zoo kernel for Python
Gérald Fenoy
gerald.fenoy at geolabs.fr
Tue Mar 22 19:04:07 PDT 2011
Armin,
can you please give me more details about the GNU/Linux distribution you are using for
trying to compile ZOO-Kernel ?
Best,
Le 22 mars 2011 à 18:06, Armin Burger a écrit :
> Gerald
> I used the command you mentioned:
> ./zoo_loader.cgi
> "request=Execute&service=WPS&version=1.0.0&Identifier=HelloPy&DataInputs=a=Demo"
> curl version is 7.15.5
> I compiled again with -DTIGER and the command still causes a segfault,
> backtrace is then:
> Core was generated by `./zoo_loader.cgi
> request=Execute&service=WPS&version=1.0.0&Identifier=HelloPy&D'.
> Program terminated with signal 11, Segmentation fault.
> #0 0xb74194db in PyObject_Malloc () from /usr/lib/libpython2.5.so.1.0
> (gdb) bt
> #1 0xb74224da in PyString_FromString () from /usr/lib/libpython2.5.so.1.0
> #2 0xb7413d73 in PyDict_SetItemString () from /usr/lib/libpython2.5.so.1.0
> #3 0xb7478e66 in PyImport_Cleanup () from /usr/lib/libpython2.5.so.1.0
> #4 0xb7484d91 in Py_Finalize () from /usr/lib/libpython2.5.so.1.0
> #5 0x080593ec in zoo_python_support (main_conf=0xbf972848,
> request=0x806e988, s=0x8073028, real_inputs=0xbf972840,
> real_outputs=0xbf972844)
> at service_internal_python.c:195
> #6 0x0804c23b in loadServiceAndRun (myMap=0xbf982cfc, s1=0x8073028,
> request_inputs=0x806e988, inputs=0xbf982cf0, ioutputs=0xbf982cf8,
> eres=0xbf982ce8)
> at zoo_service_loader.c:306
> #7 0x0804ee5d in runRequest (request_inputs=0x806e988) at
> zoo_service_loader.c:1770
> #8 0x0804b201 in cgiMain () at zoo_loader.c:264
> #9 0x080603dc in main (argc=2, argv=0xbf982e84) at cgic.c:303
> I will checl on a nother machine as well.
> armin
> On Tue, Mar 22, 2011 at 5:57 PM, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>> Armin,
>> it seems that the issue is lightly different from the first one.
>> Maybe it comes from the cURL version you are using. To confirm that
>> assumption, can you
>> try to add -DTIGER to the CFLAGS in your Makefile to then clean and
>> recompile the
>> ZOO-Kernel ?
>> If it works this mean that we have to look deeply in the cURL version
>> installed on the target
>> and check which one cause trouble and which one not. Or force installer to
>> use a specific cURL
>> version.
>> I'm currently use ZOO-Kernels linked against 7.19.6 (on GNU/Linux)
>> and 7.19.7 (on MacOS X)
>> without issue.
>> Something sounds odd to me in your last backtrace. Indeed it seems that the
>> ZOO-Kernel
>> is trying to download something but in your example it should not. Can you
>> give me the exact
>> command line you were using for getting such a result ?
>> Hope to hear from you,
>> Best,
>> Le 22 mars 2011 à 17:29, Armin Burger a écrit :
>> Gerald
>> I followed all the steps and still get the segfault message
>> <ows:Exception exceptionCode="InternalError">
>> <ows:ExceptionText>ZOO Kernel failed to process your request
>> receiving signal 11 = SIGSEGV</ows:ExceptionText>
>> </ows:Exception>
>> If I compile with USE_DBG the it writes out a core dump file,
>> analyzing it gives the message
>> #0 0xb7f317ea in curl_formadd () from /usr/lib/libcurl.so.3
>> (gdb) bt
>> #1 0xb7f41018 in curl_slist_free_all () from /usr/lib/libcurl.so.3
>> #2 0xb7f4cf67 in curl_easy_setopt () from /usr/lib/libcurl.so.3
>> #3 0x08059aaf in InternetOpen ()
>> #4 0x0804d4f0 in runRequest (request_inputs=0x806e988) at
>> zoo_service_loader.c:708
>> #5 0x0804b201 in cgiMain () at zoo_loader.c:264
>> #6 0x08060414 in main (argc=2, argv=0xbf88d584) at cgic.c:303
>> armin
>> On Tue, Mar 22, 2011 at 4:39 PM, Gérald Fenoy <gerald.fenoy at geolabs.fr>
>> wrote:
>> Hi Armin,
>> I did the following steps and everything goes right.
>> 1) Download the SVN source tree
>> 2) compile cgic206 from the SVN source tree thirds directory
>> 3) go into zoo-kernel directory and run autoconf
>> 4) run : ./configure --with-python
>> 5) create a directory zoo-dist
>> 6) copy zoo_loader.cgi and main.cfg in zoo-dist
>> 7) copy zoo-services/hello-py/test_service.py and
>> zoo-services/hello-py/cgi-env/HelloPy.zcfg in zoo-dist
>> 8) from the zoo-dist directory, I run the following :
>> ./zoo_loader.cgi
>> I get the hello world message included in the ExecuteResponse.
>> Please can you try to reproduce the steps above on your platform and
>> let me know if the error still occurs ?
>> Best
>> Le 22 mars 2011 à 14:16, Armin Burger a écrit :
>> Nick
>> I tried the SVN from today, still a segfault. I tried using GDB and
>> the only debug info I get is:
>> Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&D'.
>> #0 0xb70c4a61 in fileno_unlocked () from /lib/tls/libc.so.6
>> (gdb) bt
>> #1 0xb73ef188 in FCGI_fileno () from /usr/lib/libfcgi.so.0
>> #2 0x0804b039 in cgiMain () at zoo_loader.c:97
>> #3 0x080602b3 in main (argc=2, argv=0xbfd81284) at cgic.c:287
>> armin
>> On Thu, Mar 17, 2011 at 3:42 PM, nicolas bozon <nicolas.bozon at gmail.com>
>> wrote:
>> Hi Armin,
>> You are right, it seems we get a problem, as we could reproduce the segfault
>> this morning before going to the code sprint.
>> We'll try to solve the problem with gerald today and we'lll keep you
>> informed.
>> Best,
>> Nick
>> 2011/3/14 Armin Burger <armin.burger at gmail.com>
>> Hi all
>> after successfully compilation and installation of the zoo_loader.cgi
>> the "GetCapabilities" and "Describe Process" work fine. But as soon as
>> I try to run the Excecute request using the simple HelloPy and a
>> python serviceProvider as hello.py with
>> http://my.website/zoo/?Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&DataInputs=a=My%20Name
>> the zoo kernel returns a segmentation fault message like
>> <?xml version="1.0" encoding="UTF-8"?>
>> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xlink="http://www.w 3.org/1999/xlink"
>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>> xml:lang="en- US" version="1.1.0">
>> </ows:Exception>
>> </ows:ExceptionReport>
>> Same happens when I run it from the command line
>> ./zoo_loader.cgi
>> "Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&DataInputs=a=My%20Name"
>> So it seems sort of "caught" segfault from some internal
>> functionality. But I do not know how to do some kind of debugging.
>> Any ideas what I could try?
>> Armin
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
>> Gérald Fenoy
Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110323/9329e7d7/attachment.html>
More information about the Zoo-discuss
