[ZOO-Discuss] Problem with XML execute request
Luca Delucchi lucadeluge at gmail.com
Tue May 3 15:03:25 PDT 2011
2011/5/3 Soeren Gebbert <soerengebbert at googlemail.com>:
> Dear ZOO fellows,
> i have a problem with XML execute requests. When sending WPS XML
> execute requests using the latest ZOO SVN version the following
> problems occur:
[CUT]
> <?xml version="1.0" encoding="UTF-8"?>
> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
>  <ows:Exception exceptionCode="InternalError">
>    <ows:ExceptionText>ZOO Kernel failed to process your request
> receiving signal 11 = SIGSEGV</ows:ExceptionText>
>  </ows:Exception>
> </ows:ExceptionReport>
> Here is the apache2 log:
> http://www-pool.math.tu-berlin.de/~soeren/tmp/log.txt
> I use wps-grass-bridge and grass gis 7 as backend. The grass process
> runs perfectly but the zoo kernel crashes while trying to deliver the
> result.
I have the same problem....
> Here the wps-grass-bridge logfile:
> http://www-pool.math.tu-berlin.de/~soeren/tmp/logfile.txt
mine http://lucadelu.org/zoograss/logfile_error.txt
> Any help is greatly appreciated.
+1
> Best regards
> Soeren
regard
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
