[ZOO-Discuss] Problem with XML execute request
Pierre Roudier
pierre.roudier at gmail.com
Tue May 3 19:50:58 PDT 2011
Sorry forgot to give the link to my v_voronoi.zcfg:
http://dl.dropbox.com/u/10068638/v_voronoi.zcfg
Cheers,
Pierre
2011/5/4 Pierre Roudier <pierre.roudier at gmail.com>:
> Hi,
> I'm able to reproduce the bug as well:
> root at grass:/usr/local/src/wps-grass-bridge-read-only/Testing/Python#
> python SendRequests.py -f ExecuteRequests/v.voronoi.execute.xml -u
> "http://localhost/cgi-bin/zoo_loader.cgi"
> Start request 0
> ########### 0 ##########
> <?xml version="1.0" encoding="UTF-8"?>
> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
> <ows:Exception exceptionCode="InternalError">
> <ows:ExceptionText>ZOO Kernel failed to process your request
> receiving signal 11 = SIGSEGV</ows:ExceptionText>
> </ows:Exception>
> </ows:ExceptionReport>
> Pierre
> 2011/5/4 Luca Delucchi <lucadeluge at gmail.com>:
>> 2011/5/3 Soeren Gebbert <soerengebbert at googlemail.com>:
>>> Dear ZOO fellows,
>>> i have a problem with XML execute requests. When sending WPS XML
>>> execute requests using the latest ZOO SVN version the following
>>> problems occur:
>> [CUT]
>>> </ows:Exception>
>>> Here is the apache2 log:
>>> http://www-pool.math.tu-berlin.de/~soeren/tmp/log.txt
>>> I use wps-grass-bridge and grass gis 7 as backend. The grass process
>>> runs perfectly but the zoo kernel crashes while trying to deliver the
>>> result.
>> I have the same problem....
>>> Here the wps-grass-bridge logfile:
>>> http://www-pool.math.tu-berlin.de/~soeren/tmp/logfile.txt
>> mine http://lucadelu.org/zoograss/logfile_error.txt
>>> Any help is greatly appreciated.
>> +1
>>> Best regards
>>> Soeren
>> regard
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Scientist
> Landcare Research, New Zealand
Scientist
More information about the Zoo-discuss
