[ZOO-Discuss] Problem with XML execute request
Pierre Roudier
pierre.roudier at gmail.com
Tue May 3 19:46:57 PDT 2011
I'm able to reproduce the bug as well:
root at grass:/usr/local/src/wps-grass-bridge-read-only/Testing/Python#
python SendRequests.py -f ExecuteRequests/v.voronoi.execute.xml -u
"http://localhost/cgi-bin/zoo_loader.cgi"
Start request 0
########### 0 ##########
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
<ows:Exception exceptionCode="InternalError">
<ows:ExceptionText>ZOO Kernel failed to process your request
receiving signal 11 = SIGSEGV</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Pierre
2011/5/4 Luca Delucchi <lucadeluge at gmail.com>:
> 2011/5/3 Soeren Gebbert <soerengebbert at googlemail.com>:
>> Dear ZOO fellows,
>> i have a problem with XML execute requests. When sending WPS XML
>> execute requests using the latest ZOO SVN version the following
>> problems occur:
> [CUT]
>> </ows:Exception>
>> Here is the apache2 log:
>> http://www-pool.math.tu-berlin.de/~soeren/tmp/log.txt
>> I use wps-grass-bridge and grass gis 7 as backend. The grass process
>> runs perfectly but the zoo kernel crashes while trying to deliver the
>> result.
> I have the same problem....
>> Here the wps-grass-bridge logfile:
>> http://www-pool.math.tu-berlin.de/~soeren/tmp/logfile.txt
> mine http://lucadelu.org/zoograss/logfile_error.txt
>> Any help is greatly appreciated.
> +1
>> Best regards
>> Soeren
> regard
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Scientist
Landcare Research, New Zealand
More information about the Zoo-discuss
