[ZOO-Discuss] Problem with XML execute request
Luca Delucchi
lucadeluge at gmail.com
Wed May 4 06:35:49 PDT 2011
2011/5/4 Gérald Fenoy <gerald.fenoy at geolabs.fr>:
> Luca,
> using the zcfg file you provided it still works on my side as you can test
> using the following url :
> http://www.zoo-project.org/cgi-grass/zoo_loader_20110504.cgi
> Looking into your GGS file, something sounds odd to me, you set :
> GRASS_ADDON_PATH="/root/compilati/grass-addons"
yes I know, but I don't understand well what is the use of
GRASS_ADDON_PATH, Soeren is it the place of compiled grass addons or
the path to the svn repository? I see also
"gms/Testing/Python/GrassAddons/" can I use it in GRASS_ADDON_PATH?
> But the UNIX user running apache should not get access right (I guess and
> hope :) )
> to this directory which is owned by root. But this should not explain why
> you get the
> SIGSEGV message which I'm unable to reproduce.
yes, can you try with the last version of each part (grass, wps bridge)
> Can you confirm that you copied the zcfg files in the cgi-bin directory
> where your ZOO-Kernel
> is located and that apache get read access on those files ?
yes
ls -1 /usr/lib/cgi-bin/
buiowms
general_funct.py
GlobalGrassSettings.py
gms
line_funct.py
main.cfg
man
mapserv
php
php5
point_funct.py
proxy.cgi
r_random_cells.py
r_random_cells.zcfg
v_voronoi.py
v_voronoi.zcfg
ZOOGrassModuleStarter.py
zoo_loader.cgi
zoosm.py
zoosm.zcfg
> Hope to hear from you.
> Best,
> Gérald Fenoy
regards
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss
