[ZOO-Discuss] Problem with XML execute request
Gérald Fenoy gerald.fenoy at geolabs.fr
Wed May 4 06:25:33 PDT 2011
Luca,
using the zcfg file you provided it still works on my side as you can test using the following url :
http://www.zoo-project.org/cgi-grass/zoo_loader_20110504.cgi
Looking into your GGS file, something sounds odd to me, you set :
GRASS_ADDON_PATH="/root/compilati/grass-addons"
But the UNIX user running apache should not get access right (I guess and hope :) )
to this directory which is owned by root. But this should not explain why you get the
SIGSEGV message which I'm unable to reproduce.
Can you confirm that you copied the zcfg files in the cgi-bin directory where your ZOO-Kernel
is located and that apache get read access on those files ?
Hope to hear from you.
Best,
Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110504/1043d82d/attachment.html>
More information about the Zoo-discuss mailing list
